3E AUDIO 260-2-29A PFFB Stereo amplifier Module
The 3E Audio 260-2-29A PFFB module is a high-performance Class D amplifier that can operate in stereo (BTL) mode. It is based on the use of TPA3255 amplifier chips allowing it to develop an important power of 2x260W under 4Ω.
4.9 / 5
Reference : 17252
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 18-04-2025.
Balanced Class D Amplifier Module TPA3255 BTL 2x260W
3E Audio PFFB Module Amplificateur Stéréo Class D Symétrique TPA3255 2x 225W 4 Ohm
The 3E Audio 260-2-29A PFFB module is a high-performance Class D amplifier that can operate in stereo (BTL) mode. It is based on the use of TPA3255 amplifier chips allowing it to develop an important power of 2x260W 4Ω. A power that it provides while revealing a precise and dynamic restitution. It incorporates an advanced feedback design (Post Filter Feedback) and a proprietary high speed error correction system (PurePath™ Ultra-HD). This technology achieves a very low level of distortion across the entire frequency band and superior audio quality.
By combining Post Filter Feedback, an enhanced input stage and high quality components, the 3E Audio PFFB module achieves incredibly low noise and distortion for clear and transparent playback.
3E Audio 260-2-29A PFFB review by Audio Science Review (Amir)
I am amazed and pleased to see how much performance is extracted out of the TPA3255 class D amplifier IC here. Clearly a good designer is at work here. Noise and distortion are kept at a minimum while producing lots of power. There is some increased distortion at higher frequencies but that is a small consideration in the context of this class of amplification. "
Logo Audio Science Review
Product typeAmplifier board
Amplification typeClass D
Amplification chip2* TPA3255
Output powerBTL : 2x260W @ 4Ω, 1% THD+N
BTL : 2x150W @ 8Ω, 1% THD+N
THD+N0.0007%
Output noise18µV (A-Weighted)
Frequency response20Hz-20kHz ±0.5dB
Input impedanceSingle-ended: 10kΩ
Balanced: 20kΩ
Output impedance10mΩ
Dynamic range125dB
Supply voltage36-51VDC
Dimensions120*85mm
Package1x 3E AUDIO PFFB module
2x XH 3 pin to bare wire cable 25cm
6x Blade connector
InputPCB Connector
OutputPCB Connector
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)260.0
Download
14 reviews
mejor que purifi
Tuve una PURIFI con la desastrosa SMPS hypex y sonaba estéril y enclenque. La devolví. -purifi con fuente de alimentación lineal hubiera sido perfecta sin embargo pero no se hacerlo porque es multivoltaje - . Encargué este módulo por sus buenas medidas aprebachando que la impedancia mínima de mis cajas no es demasiado baja -este no es estable a 2 ohm como purifi- pero como es un solo voltaje se le puede meter fácil un toroidal y una fuente no regulada lineal...resultado: con un previo realmente cálido/transparente como el perfecto Glasshouse TVC, la resolución es infinita el detalle el realismo , calida valvular sin ruido pero con cuerpo con grip emocionante ¡Mucho mejor que la típica Purifi o NCORE con SMPS hypex -probablemente con una SMPS Meanwell hubiera sido mucho mejor+! Brillante suena mejor -con un previo TVC - que la clase A
This review has been posted for 3E AUDIO 260-2-29A PFFB Stereo Balanced Class D Amplifier Module TPA3255 BTL 2x260W 4 Oh
2eme avis..
Si vous montez une iec avec un porte fusible, l' ajout d' un fusible audiophile, même pas cher (aucharm alliage argent... 5€ par exemple ou un gustard a 20€) optimise les rendu sonore de ce petit bijoux !!
Parfait, à un détail prêt.
Un quasi sans faute pour ce module, puissant et qualité sonore au top (je ne m'étendrai pas sur ce sujet, pas assez d'expérience et ne maîtrise pas les termes techniques), excellent système de refroidissement.
Je vais quand même lui enlever une étoile à cause du mod à faire pour pouvoir lui fournir un signal asymétrique : nécessite de souder des OPAs (non dispos sur le site à part sur adaptateur DIP8 et donc à dessouder au préalable), et fait sauter la garantie du module.
Des sockets DIP8 auraient été un gros plus.
 (3)
Ne cherchez plus!
Si vous avez des Dynaudio emit 30 (en vente sur ce site) cet ampli est fait pour elles: une bande passante parfaite de haut en bas avec
une dynamique d'enfer , les timbres justes, et la transparence alors là un pur bonheur. Sur le lecteur cd Denon 110 anniversaire, pré -amplis FX tube 01 modifié tubes Voshkod avec symétriseur pro Sonifex ou Schiit Jotuheim phono.
Excellence audio
J'étais à la recherche d'un petit module audio pour multi-amplifier mon enceinte, une Jalucine 24.
Puis, je suis tombé sur ce module dont Audio Science Review (et d'autres) disaient le plus grand bien.
Pour l'alimenter j'ai eu recours à une SMPS Connex de 36V/300W.
A la première mise sous tension, le son était très sale (râpeux, distordu), limité dans les aigus. Un peu déçu. Puis, je l'ai laissé sous tension toute la nuit, et je n'ai plus reconnu le son que j'avais la veille, beaucoup plus fin, mieux défini.
Au troisième jour, le son est parfait (comparé à un Super 30W Classe A Hiraga), du grave à l'aigu.
Je recommande donc sans réserve.
The 3E Audio 260-2-29A PFFB module is a high-performance Class D amplifier that can operate in stereo (BTL) mode. It is based on the use of TPA3255...
