AIYIMA B2D1496 Class A/B Amplifier Board SanKen1494/3858 2x220W 4 Ohm
The AIYIMA B2D1496 is a Class A/B amplifier module. It is based on 8 SANKEN transistors, 4x 2SA1494 and 4x 2SC3858, to deliver a comfortable power of 2x220W under 4Ω or 1x400W 4 Ohm in mono mode.
Reference : 17146
75,00 €tax incl.
62,50 € tax excl.
AIYIMA B2D1496
Class A/B Amplifier SanKen1494/3858 2x220W 4Ω
AIYIMA B2D1496 SanKen1494/3858
The AIYIMA B2D1496 is a Class A/B amplifier module. It is based on 8 SANKEN transistors, 4x 2SA1494 and 4x 2SC3858, to deliver a comfortable power of 2x220W under 4Ω or 1x400W 4 Ohm in mono mode. It can be powered by 2x AC 24 - 32V, with a toroidal transformer or a power supply offering at least 400W.
This B2D1496 amplifier module of only 220x145x80mm allows to design a compact and very powerful audio system.
In order to use this amplifier module in mono mode, the K1 and K2 jumpers must be connected.
AIYIMA B2D1496 connection diagram
In order to function properly, this amplifier module needs very good heat dissipation with suitable heat sinks.
Technical specifications
Type of productAmplifier module
Amplification chips4x SANKEN 2SA1494 / 4x SANKEN 2SC3858
Type of amplifierClass A/B
Power2x 220W / 4 Ohm (with 2x AC 32V)
1x 400W / 4 Ohm (with 2x AC 32V)
THD0.05%
Input sensitivity800mV
Accepted impedances4 Ohm / 8 Ohm / 16 Ohm
general
Power supply2x AC 24 - 32V
Dimensions220x145x80mm
Package1x AIYIMA B2D1496
InputPCB Connector
OutputPCB Connector
Channel2 (Stereo)
ClassClass A / AB
Amplifier chip2SA1494 - 2SC3858
Power (W)220.0
Satisfait
Service de qualité de la part d' Audiophonics, expédition rapide et emballage correct. .
L'ampli acheté produit un son de qualité, sa fabrication est de bonne qualité. Seule la dimension en hauteur est 5mm supérieure à celle donnée dans les caractéristiques produit.
This review has been posted for AIYIMA B2D1496 Class A/B Amplifier Board SanKen1494/3858 2x220W 4 Ohm
The AIYIMA B2D1496 is a Class A/B amplifier module. It is based on 8 SANKEN transistors, 4x 2SA1494 and 4x 2SC3858, to deliver a comfortable power...
