Class D Mono TPA3110 30W 4 Ohm
This small mono Class D amplifier module is based on a TPA3110 chip, allowing it to develop a maximum power of 30W. Simple and compact, it allows the development of small amplified audio systems.
It is recommended to use a power supply voltage between 12V and 15V for a 4Ω speaker and between 12V and 20V for an 8Ω speaker.
Product type | Amplifier board |
Amplifier type | Class D |
Amplification chip | TPA3110 |
Input | Screw terminal |
Output | Screw terminal |
Output power | 1x30W |
Efficiency | 93% |
Frequency response | 35Hz - 88kHz |
Supply voltage | 10-24VDC 3A |
Dimensions | 55 x 40 x 15mm |
Mounting holes spacing | 47.5 x 33mm |
Input | Screw terminals |
Output | Screw terminals |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | TPA3110 |
Power (W) | 30.0 |
