Amplifier Board Mono Class D TPA3255 1x 140W 4 Ohm
This mono amplification module uses a TPA3255 amplification chip, allowing it to develop a substantial power of 1x250W under 4Ω (1% THD + N) while taking advantage of the high efficiency inherent in its Class D architecture.
Reference : 14858
49,90 €tax incl.
41,58 € tax excl.
Amplifier Module
Mono Class D TPA3255 1x 140W 4 Ohm + Mode Sub
Module d'amplification Mono Class D TPA3255 1x 250W 4 Ohm
This mono amplification module uses a TPA3255 amplification chip, allowing it to develop a substantial power of 1x140W under 4Ω (1% THD + N) while taking advantage of the high efficiency inherent in its Class D architecture.
It has an integrated filter (cut-off frequency at 95Hz) which is easy toggled using a two-position switch selector. This function allows this module to function as a monophonic amplifier block as well as a sub & bass amplifier block.
When the SUB mode is activated (high position), a small red LED lights up.
For this purpose, it usse an input on a stereo RCA connector in order to sum the two channels when operating in sub amplifier mode.
Three removable stand-mounted NE5532P operational amplifiers provide clear, precise volume control with a rotary potentiometer mounted in front of the PCB.
Its power input has a filtering based on electrolytic capacitors 1200UF / 50V to ensure a robust and steady power supply.
Module d'amplification Stéréo Class D TPA3255 2x 260W 4 Ohm
TypeAmplifier Module
Amplifier chip1x TPA3255
ClassD
ChannelsMono (1)
Power1x 140W @ 4 Ω, THD+N 1%, 36V
1x 260W @ 2 Ω, THD+N 1%, 36V
Input1x RCA stereo
OutputScrew terminals
Power Supply30V ~ 40V DC
Dimensions150 x 75 x 29mm
Mounting holes spacing142 x 67mm
Channel1 (Mono)
Amplifier chipTPA3255
Power (W)250.0
Ampli de qualité
Très bon rapport qualité prix pour cet ampli qui peut fonctionner en large bande ou pour alimenter un caisson de grave. Le son est excellent, musical , aucun souffle. Il est utilisé dans une ancienne radio de 30 litres avec un HP de 93db et un tweeter, le niveau sonore atteint est plutôt élevé.
This review has been posted for Amplifier Board Mono Class D TPA3255 1x 140W 4 Ohm
This mono amplification module uses a TPA3255 amplification chip, allowing it to develop a substantial power of 1x250W under 4Ω (1% THD +...
