Amplifier Module 4.0 Class AB TDA7850 4x50W 4 Ohm
The TDA7850 is a class A/B amplifier module with MOSFET technology, featuring 4 channels and capable of delivering 4x50W output power at 4 ohms. The TDA 7850 chip, mounted on a heatsink for efficient heat dissipation, is the reason for its high power and rich, detailed sound reproduction.
Reference : 18605
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 24-04-2025.
Photo of TDA7850 4.0 Amplifier Module
This TDA7850 class A/B amplifier module with MOSFET technology features 4 channels and is capable of delivering 4x50W output power at 4 ohms. The TDA7850 chip, mounted on a heatsink for efficient heat dissipation, is the reason for its high power and rich, detailed sound reproduction. This module offers high output current thanks to its rail-to-rail output structure and low distortion. Input is via a double RCA socket, and output is via screw terminals. This amplifier module accepts a voltage range from 12V DC to 18V DC, also via screw terminals.
Overview of the TDA7850 4.0 amplifier module
Input/output diagram for the TDA7850 4.0 amplifier module
1DC 12V-18V power supply input on screw terminal block
2RCA stereo input 1
3RCA stereo input 2
4Output 1 on screw terminal block
5Output 2 on screw terminal block
6Output 3 on screw terminal block
7Output 4 on screw terminal block
Product type4.0 amplifier module
Amplification typeClass A/B
Amplification chipTDA7850
Number of channels4.0
Inputs2x RCA stereo
Outputs4x Screw terminal block
Ouputs power4x 50W @ 4 ohm (18V)
Supply voltages12V DC Nominal
14.4V DC for rated power (50W)
18V DC Max
Dimensions70x 40 x 75mm
Mounting holes30 x 62
Weight94g
Package1x Amplifier module 4.0 Class AB TDA7850
OutputScrew terminals
Channel4
ClassClass A / AB
Amplifier chipTDA7850
Power (W)50.0
The TDA7850 is a class A/B amplifier module with MOSFET technology, featuring 4 channels and capable of delivering 4x50W output power at 4 ohms....
