Amplifier Module Class D 6 Channels
This amplifier module features 6 output channels and is based on 3 TPA3255 chips to deliver an output power of 260W at 4Ω and 150W at 6Ω. This module requires a power supply of 24-48V DC and integrates 3 12V power supply outputs for the fans, as well as an 8.5V auxiliary power supply output.
Reference : 20463
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 24-04-2025.
Amplifier Module Class D 6 channels 3xTPA3255 6x260W 4Ω
6-channel Class D amplifier module : Front view
This amplifier module features 6 channels and is based on 3 TPA3255 chips to deliver an output power of 6x260W at 4Ω or 6x150W at 6Ω. This module requires a power supply of 24-48V DC (sold separately) and integrates 3 12V power supply outputs for the fans, as well as an 8.5V auxiliary power supply output.
Module overview
6-channel Class D amplifier module : Diagram
1Audio output terminal
2Audio output terminal
3Audio output terminal
4Power input terminal
5Audio output terminal
6Audio output terminal
7Audio output terminal
812V power supply port for fan
912V power supply port for fan
1012V power supply port for fan
116x Unbalanced audio signal input
12Auxiliary 8.5V power port
Be careful not to confuse the input voltage of the power supply terminal block (circled in red in the photo) with the polarity of the audio outputs surrounding it.
6-channel Class D amplifier module : terminal block supply voltage
Product typeAmplifier module
Amplification typeClass D
Amplification chips3x TPA3255
Channels6
Input1x 8-pin Molex (unbalanced input)
Output6x Screw terminals
Power output6x 260W @ 4Ω 1%THD
6x 315W @ 4Ω 10%THD
6x 150W @ 6Ω 1%THD
6x 185W @ 6Ω 10%THD
Frequency response20Hz-20kHz
Dynamic range> 100dB
Signal-to-noise ratio (SNR)> 111dB
Supply voltage24-48V DC (sold separately)
Dimensions260 x 130 x 34mm
Mounting holes117 x 241mm
Weight720g
PackageSold by unit
InputMolex
OutputScrew terminals
Channel6
Amplifier chipTPA3255
Power (W)260.0
Amplifier Module Class D 6 Channels 3xTPA3255 6x260W 4 Ohm
This amplifier module features 6 output channels and is based on 3 TPA3255 chips to deliver an output power of 260W at 4Ω and 150W at...
