Class D 2x240W 4Ω
This high efficiency Class D amplifier module is based on a TI TAS5630 chip, allowing it to develop a high power of 2x 240W under 4Ω (1% THD). This chip is associated with a pair of high-performance OPA1632 AOPs ensuring very low distortion for a clear and detailed reproduction. The TAS5630 chip takes advantage of PurePath HD technology, allowing the module to achieve the performance of a Class AB amplifier, with a THD of less than 0.03%, while offering the high power and efficiency of a Class D amplifier. The module comes with a volume control using a potentiometer. The amplifier is surmounted by a large heat sink, allowing to efficiently dissipate the heat released by the electronic components.
The module also reveals a particularity in terms of its power supply. It is indeed possible to supply it with either DC or AC power.
Product type | Amplifier module |
Amplification type | Class D |
Amplification chip | TI TAS5630 |
Power | 2x 240W @ 4Ω, 1% THD 2x 160W @ 6Ω, 1% THD 2x 125W @ 8Ω, 1% THD |
Input | 1x 3 pins connector |
Output | Speaker terminals |
Frequency response | 20Hz - 20kHz |
SNR | ≥ 100dB |
THD+N | ≤ 1% |
Power supply | 20-48V DC (45VDC recommended) 10A OR 15-34V AC (26-32VAC recommended) 250W |
Dimensions | 127 x 112 x 35mm |
Input | PCB Connector |
Output | Screw terminals |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TAS5630 |
Power (W) | 240.0 |
