Amplifier Module Class D TDA8954 2x 160W 4 Ohm
This Class D amplifier module is based on a TDA8954 chip, allowing it to develop a power of 2x160W under 4Ω (THD 0.5%), and this with a high efficiency.
Reference : 14769
44,90 €tax incl.
37,42 € tax excl.
Amplifier Module TDA8954
Class D 2x160W 4Ω
Module amplificateur TDA8954 Class D 2x160W 4Ω
This Class D amplifier module is based on a TDA8954 chip, allowing it to develop a power of 2x160W under 4Ω (THD 0.5%), and this with a high efficiency. This amplifier has the particularity of being able to be powered either in DC or in AC, the selection being made via a DIP switch on the PCB. Another DIP switch allows it to use the module in BTL mode and to deliver a power of 420W (10% THD). A 12VDC output is also present, allowing to supply another audio module.
Product typeAmplifier module
Amplification typeClass D
Amplification chipNXP TDA8954
Output power2x 160W @ 4Ω, 0.5% THD
BTL : 1x420W @ 10% THD
Input1x audio input on 3 pins connector
OutputsSpeaker terminals
1x 12VDC output
Power supply12.5-42.5V DC (35VDC recommended) OR 16-28V AC (24V-0-24V AC recommended)
Dimensions128 x 105mm
Package1x TDA8954 Amplifier module
1x 3 pins XH cable to bare wires
Spacers and screws
InputPCB Connector
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTDA8954
Power (W)160.0
This Class D amplifier module is based on a TDA8954 chip, allowing it to develop a power of 2x160W under 4Ω (THD 0.5%), and this with a...
