Le son est bon, mais il reste un souffle assez présent que je ne parviens pas à supprimer!
ONsemi NJW0281G
This amplifier consists of two mono amplification modules, each based on 3 excellent ONsemi NJW0281G transistors, for a total of 6 transistors. Thanks to these transistors, each module is able to deliver 25W in Class A for a sound that is both warm and clear.
The module benefits from high quality components such as WIMA MKP, EPCOS or Nichicon capacitors. This allows in particular to enjoy a filtering and therefore a reduction of noise. In addition, the PCB benefits from a gold-plated double-sided circuit for better conductivity.
These amplifier module have to be set before being use. Read carefully this document to learn the full step-by-step procedure.
Power | 2x25W |
Amplifier type | Class A |
Transistors | 2x3 ONsemi NJW0281G |
Recommended transformer | AC12V to AC22V |
Dimensions | 136 x 55 x 43mm |
Weight | 156g |
1 | Audio Input |
2 | Audio Output |
3 | Power supply |
Input | Screw terminals |
Output | Screw terminals |
Channel | Dual Mono |
Class | Class A / AB |
Amplifier chip | NJW0281 |
Amplifier chip | Transistors |
Power (W) | 25.0 |
Average votes 3.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
