Amplifier module stereo Class D Infineon MA5332 2x150W / 4 Ohm
This Class D stereo amplifier module is based on an Infineon MA5332 amplifier chip. This module has a compact form factor, but develops an output power of up to 2x150W @ 4 Ohm.
Reference : 18553
55,90 €tax incl.
46,58 € tax excl.
Shipping date: 24-04-2025.
Amplifier Module Stereo Class D Infineon MA5332 2x150W / 4 Ohm
Photo of Infineon MA5332 Class D Stereo Amplifier Module
This Class D stereo amplifier module is based on an Infineon MA5332 amplifier chip. This module has a compact form factor, but develops an output power of up to 2x150W under 4 Ohm. It also integrates a dual NE5532 AOP, a PWM controller, 78M05, 78M10 and 79M05 voltage regulators and 6 x 50V 470uF capacitors. The MA5332 amplifier chip incorporates overvoltage, overcurrent, undervoltage and undercurrent protection. A heat sink is mounted on the MA5332 amplifier chip for efficient heat dissipation. A mute system to prevent noise on power-up completes the package.
Signal input is via a 3-pin PCB connector, while two PCB connectors with screw terminal adapters are located on the output side. Power is supplied to the module via a 3-pin PCB connector, also with screw terminal adapters. This amplifier module accepts a supply voltage range of +/-22V to +/-40V DC 8A.
A +/- 5V secondary output on soldering pads can be used to power a small preamplifier or digital-to-analog converter (DAC) module.
Overview of the Infineon MA5332 Class D stereo amplifier module
Diagram of the Infineon MA5332 Class D Stereo Amplifier Module
A1: Channel 1 input / 2: GND / 3: Channel 2 input
BExternal power supply output +/-5V
C4: GND / 5: Channel 1 output
DPower supply input +/-22V to +/-40V DC 8A
E6: GND / 7: Channel 2 output
Product typeClass D stereo amplifier module
Amplification chipnInfineon MA5332
OPANE5532
Input1x Single-ended stereo input
Ouputs1x unbalanced right-channel output on PCB connector/screw terminal block
1x unbalanced left channel output on PCB connector/screw terminal block
Additional connectors+/-5V DC power supply output on solder pads
Power output2x 150W @ 4 Ohm (THD+N = 1%, +/-36.5V DC)
2x 120W @ 2 Ohm (THD+N = 1%, +/-23V DC)
2x 110W @ 6 Ohm (THD+N = 1%, +/-40V DC)
THD+N0.01% (@ 1kHz, 70W, 4 Ohm)
Power supply+/-22V to +/-40V DC 8A (ideal +/-36.5V DC)
Dimensions100 x 62 x 25mm
Mounting holes92 x 54mm
Weight134g
Package1x MA5332 class D stereo amplifier module
1x 3-pin wiring PCB connector to bare wires
4x Screws
4x Spacer
3x Screw terminal adapter
InputPCB Connector
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipInfineon MA5332M
Power (W)150.0
Amplifier Module Stereo Class D Infineon MA5332 2x150W 4 Ohm
This Class D stereo amplifier module is based on an Infineon MA5332 amplifier chip. This module has a compact form factor, but develops an output...
