Amplifier Module TPA3116D2 with Tone Control 2x25W 8 Ohm
This small complete amplifier module is based on a TPA3116D2 amplifier chip. This allows it to deliver a power of 2x25W under 8Ω. In addition, the architecture of this chip allows it to ensure a low level of noise and distortion and high efficiency.
4.5 / 5
Reference : 13958
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 23-04-2025.
Amplifier module
TPA3116D2 2x25W 8 Ohm with tone control
Module Amplificateur TPA3116D2 2x30W 8 Ohm avec Contrôle de Tonalité
This small complete amplifier module is based on a TPA3116D2 amplifier chip. This allows it to deliver a power of 2x25W under 8Ω. In addition, the architecture of this chip allows it to ensure a low level of noise and distortion, while limiting jitter thanks to an integrated clock system and a PLL circuit. As the module operates in Class D, it has a high efficiency of more than 90%. A double NE5532 AOP takes care of the preamplification part and the tone control. The module includes both a volume knob and two other knobs to adjust the bass and treble levels, in order to adapt the playback to your system.
The module also includes a series of protection against overvoltages, undervoltages, high temperatures, short circuits and overloads. The TPA3116D2 chip is topped by a heat sink to evacuate the heat.
On the connector side, the module is simple and efficient, with screw terminals for power supply and speaker outputs, as well as a 3-pin XH 2.54mm connector to connect a source.
Product typeAmplifier module
Power2x25W @ 8Ω / 2x 50W @ 4Ω
Input1x XH 2.54mm 3 pins connector
OutputSpeaker screw terminal
Efficiency> 90%
Potentiometer shaft type 6mm Notched
Power supply12-24VDC on screw terminal (power supply sold separately)
PCB Dimensions60 x 32 x 14mm
Total dimensions (with buttons)64 x 50 x 18mm
Weight40g
Package1x Amplifier module TPA3116D2
1x XH 2.54mm 3 pins cable
3x buttons
InputXH 2.54mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)25.0
2 reviews
Bon rapports qualité prix
cet ampli fait bien le job les corrections graves aigus sont efficaces, il chauffe pas trop.
On peut même brancher un seul hp sur le + d'un côté et le - de l'autre et on a une diffusion en mono avec les 2 canaux melangé ( la masse doit être commune) mais pas de fonction bridgé.
Un petit "ploc" se fait entendre à l'allumage et l'extinction de l'ampli.
Une led rouge s'allume lors de la mise sous tension.
This review has been posted for Amplifier Module TPA3116D2 with Tone Control 2x25W 8 Ohm
Les + : Le son de qualité avec une très faible distorsion même au maximum, la petite taille, la possibilité de gérer les aiguës et les graves fort pratique pour adapter le rendu sonore à vos haut-parleur sans avoir recourt à des filtre complexes, le prix, livrés avec les boutons et les écrous pour une fixation simple
Les - : pas de bluetooth
This small complete amplifier module is based on a TPA3116D2 amplifier chip. This allows it to deliver a power of 2x25W under 8Ω. In addition, the...
