Amplifier Module with Volume Control TPA3116D2 2x50W 4 Ohm
This amplifier module is based on a TPA3116D2 amplifier chip. This allows it to deliver a power of 2x25W under 8Ω. In addition, the architecture of this chip allows it to ensure a low level of noise and distortion, and a high efficiency.
Reference : 13959
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 02-04-2025.
Amplifier module
TPA3116D2 2x50W 4 Ohm with volume control
Module Amplificateur TPA3116D2 2x30W 8 Ohm avec Contrôle de Volume
This amplifier module is based on a TPA3116D2 amplifier chip. This allows it to deliver a power of 2x25W under 8Ω. In addition, the architecture of this chip allows it to ensure a low level of noise and distortion, while limiting jitter thanks to an integrated clock system and a PLL circuit. As the module operates in Class D, it has a high efficiency of more than 90%. The module includes a potentiometer to easily adjust the volume level.
On the connector side, there is a 3.5mm jack connector and a 3-pin XH 2.54mm connector at the input. The output is made on screw terminals for speakers.
Product typeAmplifier module
Power2x30W @ 8Ω / 2x50W @ 4Ω
Inputs1x on XH 2.54mm 3 pins connector
1x Jack 3.5mm
OutputSpeaker terminals
Efficiency> 90%
Potentiometer shaft type6mm notched
Power supply5-24VDC on screw terminals (power supply sold separately)
PCB Dimensions83.5 x 50.4 x 25mm
Total dimensions (with button)101.3 x 50.4mm
Fixation holes spacing77 x 44mm
Weight60g
Package1x Amplifier module TPA3116D2
1x Button for potentiometer
Spacers
InputJack 3.5mm
InputXH 2.54mm
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)25.0
3 reviews
marche toujours bien au bout d'un an
Depuis plus d'un an que j'utilise ce petit ampli, je tenais à exprimer tout le bien que j'en pense. Pour ce prix, c'est imbattable, et en plus, je trouve le son agréable: il est branché avec des bibliothèques de qualité (HP SEAS, DIY) et sonne sur mon bureau tous les jours. Seul bémol: l'entrée minijack est pas très pratique ni très utile à cet endroit pour l'intégration dans un boitier.
This review has been posted for Amplifier Module with Volume Control TPA3116D2 2x50W 4 Ohm
ampli
bien
Good
For this price...it works! :)
This amplifier module is based on a TPA3116D2 amplifier chip. This allows it to deliver a power of 2x25W under 8Ω. In addition, the architecture of...
