Idem qu'en classe D, je me pose la même question
This small amplifier module of 100w mono bipolar produces a dynamic and detailed sound. It is ideal for designing active speakers or powerful and affordable amplifier blocks.
Strong points :
Amplifier Module Mono LM3886 100W / 8 Ohms
The APD85 amplifier module is based on 2 high-performance bipolar LM3886 circuits developed by National SemiConductor and connected in parallel. Working in Class AB, and capable for each of a continuous power of 50W under a load of 8Ω, this transistor duo can reach 270W at peak, with a coherent harmonic distortion rate of only 0.1%. With outstanding thermal and electrical stability, this amplifier is equipped with a sophisticated dual system of protection against overvoltages and undervoltages, the latter occurring when the power supply drops below 12V. This module has a link capacitor located at the input to suppress the DC component of the signal.
Note: This product requires the use of a passive radiator of appropriate size.
Note 2: This product requires a linear power supply to operate (see accessories)
This kit is delivered with the plastic insulation essential for its proper functioning to be applied between the radiator and the LM3386.
Product type | Amplifier module |
Channels | Mono (1) |
Continuous power | 100W @ 8 Ohm +/-36V 136W @ 4 Ohm +/- 28V |
Sensitivity | 1Vrms |
Gain | 27dB |
SNR | >= 92dB |
THD | 0.1% (20Hz - 20kHz) |
Recommanded power supply | -36 /+36VDC |
Dimensions | 102 x 51 x 25mm |
Weight | 62g |
Input | Screw terminals |
Output | Screw terminals |
Channel | 1 (Mono) |
Class | Class A / AB |
Amplifier chip | LM3886 |
Power (W) | 136.0 |
Average votes 3.3 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Eric T.
Bruno F.
Jean-François D.
