Ma vieille TSF s’est transformée en enceinte connectée ; tout marche nickel !!
Amplifier Board WiFi Bluetooth 5.0 60W 4 Ohm
The Arylic Up2Stream AMP Mono is a small, powerful and versatile amplifier module offering advanced wireless connectivity. The amplifier stage of the module is capable of developing a power of 60W under 4Ω.
POWERFUL STEREO SYSTEM
Two AMP Mono modules can be combined to form a powerful stereo system. The configuration is very simple and fast, in only 2 steps.
POLYVALENCE
Suitable for all situations and integrations, the AMP Mono integrates both a digital output (I2S) and an analog output (DAC).
EASY TO USE
The selection of the output mode, mono or stereo, is extremely easy, using jumpers.
The AMP Mono can be paired with a stereo amplifier to create a 2.1 audio system, or multiple modules can be placed in different rooms to create a multi-room system.
The Arylic Up2Stream AMP Mono is compatible with many streaming services such as Spotify, Qobuz, Tidal, Deezer, Napster, iHeart Radio and web radio. It will also allow you to access music stored locally on your NAS or USB storage device.
Featuring full wireless connectivity, AMP Mono allows you to stream your music over WiFi or Bluetooth 5.0, and supports DLNA, UPnP, AirPlay and Spotify Connect.
The AMP Mono can be connected to your PC via its Micro USB connector to function as an external DAC. It is also possible to use ACPWorkbench to customize the frequency and equalization settings.
The Arylic 4Stream application, available on iOS and Android, will allow you to control your AMP Mono modules simply and remotely. It will also inform you, via a notification, of the availability of a firmware update.
Product type | Amplifier board |
Channel | Mono (1) |
Power output (Mono) | 100W @ 2Ω BTL, 24V 60W @ 4Ω BTL, 21V 30W @ 8Ω BTL, 15V |
Power output (Stereo) | 2x 50W @ 4Ω BTL, 21V 2x 30W @ 8Ω BTL, 24V 2x 15W @ 8Ω BTL, 15V |
Inputs | 1x Jack 3.5mm 1x 4 pins connector 1x Micro USB 1x Ethernet RJ45 Single 10/100M |
Outputs | 1x Speaker connector (pin spacing : 5mm) 1x 4 pins connector (stereo) 1x 2 pins connector (mono) 1x SPDIF Output |
Wireless connectivity | WiFi IEEE802.11 b/g/n 2.4G Bluetooth 5.0 (SBS/AAC) |
Frequency response | 20Hz - 20kHz |
Transmission à distance Bluetooth | 10m |
THD | 0.03% @ 1kHz, 2x50W, 24V, 4Ω |
Speaker impedance | 4-8Ω |
Supported file formats | FLAC, MP3, AAC, AAC+, ALAC, APE, WAV |
Supported sampling rates | PCM up to 24bit 192kHz |
Supported transmission protocols | AirPlay, DLNA, UPnP, Spotify Connect, QPlay |
Power supply | 12-24VDC via Jack DC 5.5/2.1mm / 2 pins connector |
Dimensions | 110 x 80 x 22mm |
Package | 1x Arylic Up2Stream Amp Mono 1x Screwdriver 1x 4 pins analog connector 2x Antennas |
Input | RJ45 |
Input | Jack 3.5mm |
Input | USB |
Output | S/PDIF |
Output | I2S |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 60.0 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
