By buying this product you get 48 loyalty points
This product has been replaced by the Atohm S500-MK2-X.
Amplifier Module Class D Subwoofer 500W 4 Ohm
Specialising in the design and manufacture of high-end loudspeakers and loudspeaker cabinets, Atohm also designs and offers amplification modules with a very high level of performance. Thanks to their sophisticated signal processing, Atohm modules offer a wide range of settings and connections to meet very demanding applications, such as active subwoofers under closed load or Bass-Reflex, active loudspeakers or monophonic power blocks. All this with excellent technical performance and musicality in a small footprint.
Important studies have been carried out by the brand on components, schematics, layout topology, power supply as well as general construction to develop the best products.
The S500-X Atohm amplifier module includes many features and specifications:
It is possible to connect the module via the pre-out/subwoofer outputs of a preamplifier/processor or directly to the speaker outputs (in parallel) of a conventional stereo amplifier. The S500-X module can also be by-passed to high performance HiFi broadband (mono block) via a simple internal switch. In this case, only the gain control remains active. This can be used, for example, to create monitor loudspeakers.
Product type | Amplifier module |
Amplification type | Class D |
Power | 500W RMS |
Impedance | 4-16Ω |
Frequency respons (direct mode) | 20Hz - 20kHz (+/-0.3dB) 1.5Hz - 90kHz (+/-3dB) |
SNR | Direct mode : 111dB |
Damping factor (8Ω, 100Hz) | > 1000 |
THD+N | < 0.1% |
Variable low pass filter | 38Hz to 200Hz, 24dB/octave or 12dB/octave (disengageable LFE) |
Phase invertor | 0-180° |
Supply voltage | 220V / 115V / 50Hz |
Consumption | 700W Max. |
Weight | 1.2kg |
Package | 1x Atohm S500-X Speaker cable Power cable |
Input | RCA |
Output | Speaker terminal |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | Ice Power |
Power (W) | 500.0 |
