Based on an architecture Class-D, this AUDIOPHONICS amplifier module is characterized by a main input in SPDIF, coaxial or Toslink.
The amplifier switches directly from the SPDIF signal to the HP output without converting to analog, so the signal is as direct as possible.
For some applications that require it, an analog input has been added to the STA328 circuit, but it is slightly noisy.
This module has many features like an Equalizer and Integrated DAC (FDA).
Indeed this amplifier to operate in 2 different ways:
- Classic Stereo Amplifier
The chip STA 328 integrated, it is possible to achieve 2 x 60 Watts under 8Ω with a harmonic distortion level of 1%.
This module also integrates a complete control to the remote control, allowing to select the inputs, to set the equalizer and to manage the volume.
afin protecting your speakers, this card has a one protection circuitagainst the possible presence of a continuous component.
A timer also avoids unpleasant noise when switched on.
Char:
Specifications:
User manual(PDF)
Amplifier + DAC / ADC Module
Remote control
display
Example of implementation based on this module:
