This BerryBak BVS26B Bluetooth 5.0 amplifier module incorporates a Class F MIX3901 amplifier chip for output power at 2x6W under 4Ω and 2x3W under 8Ω. Audio signal input is via Bluetooth, and output on screw terminal for right and left channels. A small potentiometer controls the sound volume on the PCB, and a 5-pin connector lets you add a more elaborate external volume control module. A small button activates or deactivates the Bluetooth TWS (True Wireless stereo) function for an immersive, high-quality sound experience requiring two BerryBak BVS26B modules.
Power supply is provided by a TP4056 chip with a 26650 battery socket under the PCB. There's also a USB-C connector for DC 5V powering of the BVS26 amplifier module. A small switch also enables powering.
Using a single BerryBak BVS26B amplifier module, you'll obtain classic stereo sound with 2x6W @ 4 ohm power. Simply connect two small speakers to the module via its screw terminal outputs.
To enjoy the TWS function, you'll need 2 BerryBak BVS26B modules. One will take care of the right channel, while the other will handle the left for increased power and more immersive sound. The TWS function makes it possible to broadcast true stereo sound wirelessly to several devices simultaneously. To use the TWS function, simply follow the steps below:
1 | TWS Button |
2 | Potentiometer |
3 | 5-pin connector for external potentiometer/volume control module |
4 | Bluetooth antenna |
5 | Stereo output on screw terminal |
6 | Rechargeable battery compartment (under PCB) |
7 | USB-C connector |
8 | Power switch |
Product type | Amplifier module |
Channels | Stereo |
Amplifier chip | MIX3901 |
Amplification type | Class F |
Output power | 2x 6W @ 4Ω 2x 3W @ 8Ω |
Input | Bluetooth 5.0 |
Output | Unbalanced stereo line output on screw terminal block |
Battery socket | 26650 |
Power supply | 5V DC (USB-C) |
Total dimensions | 91.44 x 30 x 40.50 |
Spacings | 83.82 x 22.86mm |
Weight | 26.5g |
Package | 1x BERRYBAK BVS26B amplifier module |
Input |
Output |
Channel |
Class |
Amplifier chip |
Power (W) |
