Class D Stereo Amplifier Module Bluetooth 4.2 USB Player 2x15W 8 Ohm
This small Class D amplifier module is capable of delivering, thanks to its OEP30Wx2 chip, up to 2x15W with a high efficiency of 90%. Despite its small size, this module is versatile since it offers 3.5mm jack, USB-A 2.0 and especially a Bluetooth 4.2 reception allowing you to broadcast your audio files remotely. The amplifier also includes a volume control and an IR receiver that allows you to control all the functions of the module remotely using the remote control provided. The module is output and powered via screw terminals.
This module is ideal for the DIY design of a small amplified audio system such as a compact Bluetooth speaker.
It is strongly recommended to use a radiator to dissipate the heat released by the amplifier chip.
Product type | Amplifier module |
Amplification class | D |
Amplification chip | OEP30Wx2 |
Power | 2x30W @ 8Ω, 24V (THD+N 10%) 2x15W @ 8Ω, 18V (THD+N 1%) 2x22W @ 4Ω, 16V (THD+N 10%) 2x15W @ 4Ω, 14V (THD+N 1%) |
Inputs | Bluetooth 4.2 1x USB-A 2.0 1x Jack 6.35mm |
Output | Speaker terminal |
SNR | 102dB |
Frequency response | 20Hz - 20kHz |
Protection | Short circuit |
Power supply | 7.5-24V DC |
Remote control battery | 1x CR2025 (sold separately) |
Min/Max operating temperature | -40°C - 85°C |
Dimensions | 50 x 31mm x 20mm |
Input | Jack 3.5mm |
Input | Bluetooth |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | OEP30Wx2 |
Power (W) | 30.0 |
Power (W) | 15.0 |
