Class D Stereo Amplifier Module MA12070 2x80W 4 Ohm
This amplifier module is based on an Infineon MA1270 Class D amplifier chip. It uses two power half-bridges with 4 MOSFETs where each transistor is driven by its own separate PWM signal. This highly efficient circuit offers remarkable performance while maintaining a very compact form-factor.
4.3 / 5
Reference : 14732
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 24-04-2025.
Module MA12070
Stereo Amplifier MA12070 2x80W @ 4 ohms
Module amplificateur 1.0 / 2.0 / 2.1 / 4.0 Class D MA12070 160W 4 Ohm
Capable of developing up to 2x80W at 4 Ohm in its stereo 2.0 mode, it is an ideal solution for your integrated amplifier / speakers & active monitors projects. Its multiple switching power supply circuit (3rd and 5th degree modulation) make it a very low energy consumption and formidable efficiency amplifier solution.
Very musical, its amplification circuit offers a signal / noise ratio superior to 110dB with an extremely low background noise (7.45µV), which makes it a solution of choice for your on-board High Fidelity projects.
Heatsink & Spacers
The MA12070 module is read with its (large) radiator already mounted and fixed. The latter ensures excellent heat dissipation in addition to the integrated protections against overheating. This ensures ideal operating conditions for the Infineon chip
Likewise, 4 spacers and 4 screws are supplied & already mounted on the module. All there is to do to obtain a functional amplifier is to power the module and plug in your other modules / devices.
Module Amplificateur 1.0 / 2.0 / 2.1 / 4.0 Class D MA12070 160W 4 Ohm
1Jack 3.5mm AUX output
2Unbalanced input
326V power supply
4Speaker outputs
TypeAmplifier module
Amplifier chip1x MA12070
Amplification technologyClass D
Channels2.0
Power @26V PVDD, RL = 4Ω, THD+N = 10%2 x 80W
Idle consumption≤160mW
SNR≥110dB
Noise (A-weighted)7. 45µV
Dimensions60 x 80 x 33 mm
Spacer50 x 70 mm
Power Supply24 - 26VDC
InputScrew terminals
OutputScrew terminals
Channel2.1
Channel1 (Mono)
Channel4
Channel2 (Stereo)
Amplifier chipInfineon MA12070
Power (W)160.0
3 reviews
Excellent module
Excellent module amplificateur, outre les possibilités de configurations (du mono au quadri) la qualité est bluffante, associé à la SMSP 300 le résultat est Top, de plus les dimensions permettent d'implanter un double mono dans le même boitier avec une seule SMPS300.
Les EMI sont compatibles avec la réception radio sans parasites.
This review has been posted for Class D Stereo Amplifier Module MA12070 2x80W 4 Ohm
Manque de sensibilité
Un très bon son mais hélas pas suffisamment sensible pour exploiter la puissance avec le seul réglage de volume d'un téléphone mobile, livré sans notice et sans le connecteur d'entée ligne
Modules MA12070 Infineon en double Mono
J'ai monté une configuration double Mono avec deux modules et deux alimentations SMPS 24V/150W. Je suis assez épaté du résultat... c'est proche d'un TPA3251 (je parle d'une version haut de gamme pas made in China).
La version que l'on voit sur les photos est la revision 1.2. J'ai reçu la nouvelle révision 1.3 avec un connecteur "ground" en plus.
Prevoyez des sections de cables fines car les connecteurs de type "push" ont un petit diamètre.
A l'écoute :
+ + c'est dynamique, musical avec une bonne source obligatoire
++le THD donné par Infineon est très intéressant,
++circuit Anti pop, pas de souffle, c'est propre
-- manque de patate. pas aussi puissant qu'un TPA3251/55 de bonne facture (avec PFFB). On droit approcher les 2X90W sous 8ohms en double Mono. Mais suffisant pour une pièce de 40m2 à volume sympa.
This amplifier module is based on an Infineon MA1270 Class D amplifier chip. It uses two power half-bridges with 4 MOSFETs where each transistor is...
