Class D Stereo Amplifier Module TPA3250 2x100W 4 Ohm
This Class D stereo amplifier module is equipped with a TPA3250 chip allowing it to deliver 2x100W of power at 4Ω, and this with high efficiency. A chip that also takes advantage of the PurePath™ Ultra-HD architecture, ensuring a very low level of distortion over the entire frequency range for a precise, detailed and clear sound reproduction.
Reference : 17313
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 24-04-2025.
Amplifier module
Stereo Class D TPA3250 2x100W 4Ω
Module amplificateur stéréo Class D TPA3250 2x100W 4Ω
This Class D stereo amplifier module is equipped with a TPA3250 chip allowing it to deliver 2x100W of power at 4Ω, and this with high efficiency. A chip that also takes advantage of the PurePath™ Ultra-HD architecture, ensuring a very low level of distortion over the entire frequency range for a precise, detailed and clear sound reproduction. The input to the module is in analog on XH2.54mm connector and the output on screw terminals.
Product typeAmplifier
Amplification typeClass D
ChannelsStereo (2)
Amplification chipTPA3250
Output power2*100W @ 4Ω, 32V, 1% THD+N
2*60W @ 8Ω, 32V, 1% THD+N
Efficiency90%
Static current50mA
Max output current4A
Supply voltage18-32VDC (power supply sold separately)
Dimensions103*78*15mm
Mounting holes spacing96*71mm
Weight80g
InputPCB Connector
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3250
Power (W)100.0
This Class D stereo amplifier module is equipped with a TPA3250 chip allowing it to deliver 2x100W of power at 4Ω, and this with high...
