Class T Stereo Amplifier Module Tripath TA2022 2x90W 4 Ohm
This Class T stereo amplifier module is equipped with a Tripath TA2022 amplifier chip, allowing it to deliver 90W of power under 4Ω per channel. This substantial energy reserve combined with high efficiency allows it to be associated with a large number of speakers, including demanding models.
Reference : 13965
29,90 €tax incl.
24,92 € tax excl.
Amplifier module
Stereo Class T TA2022 2x90W 4Ω
Module amplificateur stéréo Class T TA2022 2x90W 4Ω
The entire module benefits from a high quality design including a KBJ1010 diode bridge, 2 Samyoung 3300µF 50V filter capacitors and a power circuit control using a L7805CV voltage regulator, in order to supply the entire circuit in a clean and stable way. This double-sided PCB also contains 4 Siemens 2.2µF coupling capacitors at the signal input and high precision resistors (+/-1% tolerance) to ensure a very good SNR.
On the connector side, the module simply offers a stereo input on XH 2.54mm 3 pins connector and an output to speakers on screw terminals. Finally, a 6mm notched shaft potentiometer controls the volume level.
It is essential to combine this module with a suitable heat sink (sold separately) in order to properly dissipate the heat released by the amplifier chip. A temperature too high to irreversibly damage the equipment.
Product typeAmplification module
Amplification chipTripath TA2022
Amplification typeClass T
Power2x90W @ 4Ω
Input1x XH 2.54mm 3 pins connector
Output1x Speaker screw terminals
Total dimensions98.4 x 82 x 36.8mm
Fixation holes spacing89 x 59mm
Power supply22VAC - 0 - 22VAC
InputXH 2.54mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTA2022
Power (W)90.0
This Class T stereo amplifier module is equipped with a Tripath TA2022 amplifier chip, allowing it to deliver 90W of power under 4Ω per channel....
