CONNEX Amplifier Kit Class D CxD500 500W mono + SMPS600RXE 600W
This Connex kit, comprising a 500W Class D CxD500 Mono amplifier rated at 4 ohms and its switch-mode power supply (SMPS), gives you a solid base for all your powerful amplification needs. Based on the IR2092S controller and IRFB4227 MOSFET transistors, this amplifier delivers impressive power in a compact package.
Reference : 8237
199,00 €tax incl.
165,83 € tax excl.
Kit Module Amplificateur Class D CxD500 500W mono + Alimentation SMPS600RXE 600W
This Connex kit, comprising a 500W Class D CxD500 Mono amplifier rated at 4 ohms and its switch-mode power supply SMPS600RXE, gives you a solid base for all your powerful amplification needs. Based on the IR2092S controller and IRFB4227 MOSFET transistors, this amplifier delivers impressive power in a compact package. A built-in anti-"ploc" system enables the module to be switched on and off silently. It is necessary to attach the aluminum heat sink to the housing to improve dissipation.
This module requires a DC supply voltage in the range +-62V to +-86V for the power stage, a DC input voltage of +-18 to +-28V 20-30mA for the input stage and a separate voltage, referenced to V- with value in the range 16V to 25V at 40-50mA for the driver stage. The appropriate power supply for a CxD500 amplifier module to obtain 500W power at 4 ohms is the SMPS600RXE module from CONNEX.
SMPS600RXE : Switching Power Supply 600W / +/-72V
The Connex SMPS600RXE switch mode power supply is a very high-efficiency model capable of developing a nominal power of 600W in an extremely small footprint. The SMPS600RXE incorporates overcurrent protection which limits the output current to around 120% of the maximum peak power (760W), equivalent to around 800W. The version supplied is +/- 72 V. It also features a low-consumption differential output, +-24V at 200mA, and a low-consumption 24V 300mA output.
The main feature of this power supply is the absence of heat sinks for both power switches and rectifier diodes. The amount of EMI is lower than any conventional power supply, and could be compared to a linear regulated power supply.
Connex CxD500 + SMPS600RXE connectivity
CONNEX Kit Module Amplificateur Class D CxD500 500W mono + Alimentation SMPS600RXE 600W
1HP output on phoenix connector
2Main power input on phoenix connector
3Micro JST 1.25mm 8-pin secondary power input
4Audio signal input XH 2.54 7-pin connector
5Secondary power outputs AUX 1/AUX 2 Micro JST 1.25mm 8 pins
6Main supply output +/- 72V
7Power supply input
8Selection jumper 230V to 120V
Product typeKit CxD500 amplifier module + SMPS600RXE power supply module
ChannelsMono (1)
Amplification typeClass D
Inputs1x Audio input PCB connector XH2.54 7pins
1x Power supply input 3-contact phoenix terminal block
1x Micro JST 1.54mm secondary power input
Output1x HP output phoenix terminal block 2 contacts
ControllerIRS2092S
TransistorsIRFB4227 (MOSFET)
Power500W @ 4Ω
Dimensions100 x 40 x 35mm
Mounting holes32 x 92 mm (M3)
WeightApprox. 0.11kg
ProtectionOvercurrent / overvoltage / undervoltage / overtemperature
SMPS600RXE POWER MODULE
Input voltage range120V or 230V AC (supplied in 230V, 120V selection jumper on PCB)
Input1x Power supply input 120V / 230V
Outputs1x Main power supply output +/- 72V
1x AUX 1 / AUX 2 Micro JST 1.25mm 8 pins secondary power outputs
Nominal power600W
Maximum power760W
Output voltage+/- 72V
Auxiliary output voltage and current+/- 24V 200mA
24V300mA
WeightApprox. 0.5kg
InputXH 2.54mm
InputPCB Connector
OutputPhoenix connector
Channel1 (Mono)
Amplifier chipTransistors
Power (W)500.0
This Connex kit, comprising a 500W Class D CxD500 Mono amplifier rated at 4 ohms and its switch-mode power...
