CONNEX IRS2092 Amplifier Stereo Class D 2x 700W 4 Ohm
The Connex IRS2092 stereo amplifier module incorporates all the necessary circuitry to build a complete Class D amplifier. The module is based on a duo of Infineon (International Rectifier) IRS2092 chips, allowing it to develop a power of 2x700W under 8Ω or 2x370W under 8Ω, with great precision and richness of sound.
Reference : 14694
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 16-04-2025.
Connex IRS2092
Connex IRS2092 Module Amplificateur Stéréo Class D 2x700W 4 Ohm
The Connex IRS2092 stereo amplifier module incorporates all the necessary circuitry to build a complete Class D amplifier. The module is based on a duo of Infineon (International Rectifier) IRS2092 chips, allowing it to develop a power of 2x700W under 8Ω or 2x370W under 8Ω, with great precision and richness of sound. A series of voltage regulators provide all the circuits with a clean power supply, the heat released being efficiently dissipated by a large radiator. The module's input, on a 9-pin connector, allows the choice of connecting balanced XLR or unbalanced RCA connectors.
If a Connex power supply recommended by the manufacturer is not used to power the module, then the module will require, in addition to the +/-VCC power supply, additional +AUX, -AUX and Vbias power supplies to be distributed on the AuxSupply connector.
Input connector pinout
Pin 1Inverting Input for Left Channel
Pin 2GND Signal
Pin 3Non-Inverting Input for Left Channel
Pin 4GND Signal
Pin 5Mute Control
Pin 6GND Signal
Pin 7Non-Inverting Input for Right Channel
Pin 8GND Signal
Pin 9Inverting Input for Right Channel
Product typeAmplifier
Amplification chip2x Infineon (International Rectifier) IRS2092
Amplification typeClass D
Channels2 (Stereo)
Power2x726W @ 4Ω, 0.1% THD+N, ±86V
2x373W @ 8Ω, 0.1% THD+N, ±86V
Power in bridge mode2376W @ 4Ω, 0.1% THD+N
1420W @ 8Ω, 0.1% THD+N
THD+N0.01% @ 607W, 4Ω
0.01% @ 329W, 8Ω
EfficiencyUp to 97.2% @ 2x386W, 8Ω, ±84V, 1% THD
ProtectionsShort circuit
Overcurrents
Thermal protection
Over voltage
Under voltage
Supply voltage±80V to ±92V
Dimensions100 x 100 x 50mm
InputPCB Connector
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipInfineon IRS2092
Power (W)700.0
Connex IRS 2092 2x700
Angeschlossen an einem Hypex SMPS 1200A700
Ich habe diese Endstufe nur im Bassbereich getestet.
Klingt deutlich kraftvoller und punchiger als die 400Watt Variante.
Von der Leistung her allen Bedinungen im Haus gewachsen.
Achtung: Unbedingt für mehr Kühlfläche sorgen. Der angebaute Kühlkörper ist deutlich zu klein. Wird sehr warm.
This review has been posted for CONNEX IRS2092 Amplifier Stereo Class D 2x 700W 4 Ohm
The Connex IRS2092 stereo amplifier module incorporates all the necessary circuitry to build a complete Class D amplifier. The module is based on a...
