CONNEX IRS2200SMPS 230V Class D Amplifier Board IRS2092S 2x200W 4 Ohm
The Connex IRS2200SMPS is a Class D amplifier module with integrated power supply. It is based on two IRS2092S chips (one per channel) to deliver a power of 2x200W under 4Ω (THD < 0.1%) or 2x115W under 8Ω (THD < 0.1%), with a high efficiency of more than 94%.
Reference : 14835
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 22-04-2025.
Connex IRS2200SMPS 230V
Connex IRS2200SMPS Amplificateur Class D IRS2092S 2x200W 4Ω
The Connex IRS2200SMPS is a Class D amplifier module with integrated power supply. It is based on two IRS2092S chips (one per channel) to deliver a power of 2x200W under 4Ω (THD < 0.1%) or 2x115W under 8Ω (THD < 0.1%), with a high efficiency of more than 94%. It need to be supplied in 230V and has an efficient regulation. The power supply stage of the module ensures a stable and isolated electrical signal for the amplifier.
The input stage offers a balanced input with an impedance of 2x10K and a complete protection system. Several heat sinks allow to dissipate efficiently the heat released by the electronic components.
Compact, this amplifier of only 130x100x30mm for 350g makes it possible to design a compact, powerful and efficient audio system.
Product typeAmplifier module
Amplifier typeClass D
Power2x 200W @ 4Ω (THD < 1%)
2x 230W @ 4Ω (THD = 1%)
2x 115W @ 8Ω (THD < 0.1%)
2x 135W @ 8Ω (THD = 1%)
Gain18.85 dB
Input sensitivity1.5V RMS @ 200W 4Ω
Input impedance20K Ohm
Damping factor> 320
Linearity1.3dB from 24Hz to 18kHz
3dB drom 16Hz to 22kHz
ProtectionsOver currents
Over voltages
Under voltages
Thermal protection
DC speaker protection
Amplifier efficiency> 94% @ 4Ω
> 96% @ 8Ω
SMPS Power supply efficiency> 93.5% @ 50% load
Global efficiency88% @ 4Ω
90% @ 8Ω
Supply voltage230V (210-245V)
Dimensions130 x 100 x 30mm
Mouting holes spacing122 x 92mm
Weight365g
Package1x IRS2200SMPS
1x 3 PIN to bare wire cable 20cm
1x 4 PIN to bare wire cable 20cm
1x 9 PIN cable to bare wire 15cm
InputPCB Connector
OutputPCB Connector
Channel2 (Stereo)
Amplifier chipInfineon IRS2092
Power (W)200.0
The Connex IRS2200SMPS is a Class D amplifier module with integrated power supply. It is based on two IRS2092S chips (one per channel) to deliver a...
