CONNEX IRS2400SMPS Class D Amplifier Module IRS2092S 2x 400W 4Ω
The Connex IRS2400SMPS is a Class D amplifier module with integrated power supply. The amplifier stage is based on an IRS2092S controller, delivering a power of 2x 400W at 4Ω (THD < 0.1%) and 2x 225W at 8Ω (THD < 0.1%) with a high efficiency of more than 94%.
By buying this product you get 27 loyalty points
Reference : 14863
279,00 €tax incl.
232,50 € tax excl.
Shipping date: 18-04-2025.
Connex IRS2400SMPS
Connex IRS2400SMPS Module Amplificateur Class D IRS2092S 2x 400W 4Ω
The IRS2400SMPS can be supplied with 120VAC (100-127V) or 230VAC (210-245V) and has an efficient regulation system. The power supply stage of the module provides a stable and isolated electrical signal to the amplifier.
Its input stage offers a balanced input with an impedance of 2x10K and a complete protection system. Several radiators allow to efficiently dissipate the heat released by the electronic components.
Compact, this amplifier of only 120 x 220 x 38mm for 850g makes it possible to design a compact, powerful and efficient audio system.
Product typeAmplifier module
Amplifier typeClass D
Power2x 400W @ 4Ω (THD < 0.1%)
2x 440W @ 4Ω (THD 1%)
2x 225W @ 8Ω (THD < 0.1%)
2x 235W @ 8Ω (THD 1%)
Gain21.5dB
Input sensitivity1.5V RMS @ 200W 4Ω
Input impedance20kΩ
Damping factor> 530
Linearity1.3dB from 24Hz to 18kHz
3dB from 16Hz to 22kHz
ProtectionsOver current
Over voltage
Under voltage
Thermal protection
Speaker DC protection
Amplifier efficiency> 94% @ 4Ω
> 95% @ 8Ω
SMPS Power supply efficiency> 93.5% @ 50% load
Global efficiency88% @ 4Ω
90% @ 8Ω
Voltage supply120VAC (100-127V)
230VAC (210-245V)
Dimensions120 x 220 x 38mm
Weight850g
InputPCB Connector
OutputNC
Channel2 (Stereo)
Amplifier chipInfineon IRS2092
Power (W)400.0
The Connex IRS2400SMPS is a Class D amplifier module with integrated power supply. The amplifier stage is based on an IRS2092S controller,...
