CXD2160 Stereo Amplifier Class D Module 166W / 8 Ohms
Reference : 11986
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 22-04-2025.
Class D Stereo Amplifier Module CxD2160
This Connex CxD2160 Stereo Class D amplifier module is equipped with two IRS2092S controllers (one for each channel), enabling it to deliver impressive power for minimum footprint. The amplifier is particularly suitable for 8 Ohm loudspeakers and is capable of delivering 160W per channel, while offering a THD of less than 0.1% at nominal power or 0.024% between 10 and 80W when powered with a +/- 55V power supply .
Its small footprint will allow you to easily integrate it into your DIY creations.
This module is also available as a kit with a perfectly adapted SMPS320QR Connex power supply.
Need more information ? Download the documentation.
If a Connex power supply recommended by the manufacturer is not used to power the module, then the module will require, in addition to the +/-VCC power supply, additional +AUX, -AUX and Vbias power supplies to be distributed on the AuxSupply connector.
TECHNICAL CHARACTERISTICS
  • Controller: IRS2092S
  • Mosfets: IRFI 4019HG
  • Output Power: 166W @ 8 Ohms / 214W @ 4 Ohms
  • THD + N: 0.024% to 68W across all frequency ranges
  • Double channel
  • Class D
  • Protections: short-circuit, over-voltage, undervoltage, excessive heat, over-current
  • Dimensions: 100 x 50 x 30mm
  • Spacing: 40 x 90mm
  • M3 threaded 3-hole radiator for easy installation
  • Weight: 98g
Module amplificateur Stéréo Class D CxD2160
InputXH 2.54mm
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipInfineon IRS2092
Power (W)166.0
Excellent produit
Ampli utilisé avec une alimentation smps600Rxe (+/-55v) et un radiateur pour fonctionner sous 4 Ohm et un potard de 50K en atténuation.
Cet ensemble alimente des enceintes Magnepan 1.6QR de faible rendement, en remplacement d'un amplificateur Marantz PM80 classe A/AB de 2x160W/4 Ohm.
Pour 20 fois moins lourd, mais avec plus de 200W disponibles sous 4 Ohm, cet amplificateur est parfaitement à l'aise et ne rugit pas devant le Marantz pourtant très bon.
Aucun bruit de fond, aucune ronflette même à fond. Le haut du spectre est clairement plus précis.
Très impressionnant au vu du prix. Je conseille fortement.
Attention, le connecteur d'alimentation est livré mais pas celui des entrées audio.
This review has been posted for CXD2160 Stereo Amplifier Class D Module 166W / 8 Ohms
