DAYTON AUDIO DTA-2 Amplifier Stereo Class T 15W / 8 Ohm
4.5 / 5
Reference : 8935
27,90 €tax incl.
23,25 € tax excl.
Dayton Audio DTA-2
Class T amplifier module
Module DTA2 stereo amplification
This class T amplifier module operates with a Tripath TA2024.chip
Its high electrical efficiency (81% @ 15W - 4Ω) and small size make it an ideal component for a compact and powerful audio application.
The card has a volume control function thanks to a potentiometer mouned on its own pcb (included).
The potentiometer, when placed in minimal position, also works as a switch that can turn the device on/off.
All basic connector is supplied with the module. The cables, LED, output filter capacitor and even ferrite cores to protect the signal from interferences.
Dimensions
amplification module dayton dta-2 audio
distances
Dayton Audio DTA 2
TypeAmplification module
ClassT
Canalsx2
functionsAmplification
Volume Control
ON / OFF switch
Power2x 11W @ 4Ω, 8Ω 6W (0.1% THD + N)
2x 15W @ 4Ω, 8Ω @ 10W (10% THD + N)
Efficiency81% @ 15W, 4Ω
90% @ 10W, 8Ω
Dynamic98dB
protectionsOvercurrent
Overheated
Power supply12V DC 2A / NOT PROVIDED
Package Contents
PCB amplifier modulex1
PCB Volume Controlx1
Cable to volume connection - 30cmx1
LED status indicatorx1
Speaker cables (bare wire / black and red) - 30 cmx2
Power Cables (naked wire / black and red) - 30 cmx2
Cables LED (naked wire / black and red)x2
Capacitorsx2
Ferrite coresx2
2 reviews
correspond pas a la description mais fonctionne
j'ai reçu une version avec TDA7491P qui est un circuit classe D.
le schéma n'est pas le bon !
(pas pratique pour ajuster le montage)
toutefois, il est fonctionnel...
This review has been posted for DAYTON AUDIO DTA-2 Amplifier Stereo Class T 15W / 8 Ohm
DAYTON AUDIO DTA-2
Utilisé pour moderniser/marabouter un vieux poste radio tsf de 1957 :
Seul reproche , des borniers vis pour brancher les haut parleurs auraient été plus facile , un concurrent du tinysine tsa2210 qui possedent un bouton de mise en marche/réglage de volume déporté
