DAYTON AUDIO SBA302-BT DIY Kit Amplifier Bluetooth IR Receiver for Sound Bar 2x30W 4 Ohm
The Dayton Audio SBA302-BT Soundbar Amplifier Kit makes it easy to design your own modern soundbar. With separate input/amplifier, control and infrared receiver modules, you can create a custom sound bar with all the features common to models on the market.
Reference : 15842
175,00 €tax incl.
145,83 € tax excl.
This product is temporarily unavailable.
Dayton Audio SBA302-BT Kit DIY Amplificateur Récepteur Bluetooth IR pour Barre de Son 2x30W 4 Ohm
For easy connection to most TV sets, the SBA302-BT has a wide range of inputs, including 3.5mm line level jack, Toslink optical and ARC HDMI. All cable inputs are recessed into the amplifier module, allowing for a flat soundbar design that can be installed close to a wall. In addition, a Bluetooth input offers the possibility to stream audio remotely, directly from a smartphone, tablet or any other connected device.
For added convenience, the SBA302-BT offers two control methods. The first uses the wired control module, allowing you to control power, volume level and active input directly from the soundbar. The second option uses the infrared remote control, which allows for remote control.
Input & Amplification module
The Amplifier and Input Module is the main component of the SBA302-BT, integrating the audio inputs, power supply and amplifier board. This unit has a small footprint and allows for compact soundbar designs. Moreover, its input panel allows it to be connected to most of the TV sets on the market. Finally, all the connections are embedded in the module allowing an installation close to a wall.
Control module
With the control module you can operate most functions directly from the sound bar. This module has separate buttons for power supply, input selection and volume control. Like the amplifier module, the control module is particularly compact for easy installation. The SPA302-BT can also be programmed to control all functions of this module from any infrared remote control.
IR module
Designed to be mounted on the front of your soundbar, the IR module receives the signal from the supplied wireless remote control and has built-in status lights. These indicate which input is selected, signal the presence of a Dolby Digital signal and flash to indicate volume settings. For added convenience, the status lights can be turned on or off using the remote control.
Remote control
The supplied IR remote control allows you to easily control all the functions of the SPA302-BT remotely, from your sofa. It has the same functions as the control module: power management, source selection, volume control. It also allows you to activate or deactivate the mute mode, the status LEDs and to select a predefined equalizer among the 4 proposed.
Product typeDIY kit amplifier + BT receiver + IR receiver for sound bar
Output power2x30W RMS
Minimum impedance4Ω
Inputs1x Jack 3.5mm
1x Optical Toslink
1x HDMI ARC
Bluetooth
OutputsOn wires
Bluetooth version5.0
Bluetooth rangeUp to 20m
THD< 1% @ rated power
SNR> 96.3dB @ A-Weighted
Max input sensitivity2.3V RMS
Frequency response18Hz - 20kHz
Power supplyInput : 100~240VAC 50/60Hz
Output : 18VDC 3A
ConsumptionMax : 66.5W
Standby : 0.5W
Amplifier module dimensions215.9 x 76.2 x 46mm
Amplifier module cutout dimensions200 x 31mm
Control module dimensions88.9 x 10.2 x 58mm
Control module cutout dimensions60 x 31.7mm
IR module dimensions46 x 58mm
IR module cutout dimensions31 x 38.9mm
InputHDMI
InputJack 3.5mm
OutputNC
Channel2 (Stereo)
Amplifier chipN/A
Power (W)30.0
The Dayton Audio SBA302-BT Soundbar Amplifier Kit makes it easy to design your own modern soundbar. With separate input/amplifier, control and...
