DAYTON AUDIO SPA1200DSP Subwoofer Amplifier Module with DSP 1200W
This amplifier module for Dayton Audio SPA1200DSP subwoofer is capable of delivering no less than 1200W. A significant energy reserve allowing subwoofer enthusiasts to easily use them for deep bass reproduction. This module integrated on a plate can be integrated directly on the subwoofer body for an active subwoofer.
By buying this product you get 79 loyalty points
Reference : 13569
799,00 €tax incl.
665,83 € tax excl.
Attention: The product is delivered configured in 110V. If your electrical network provides a voltage of 220V (Europe), it is imperative to configure the device in 220V using the switch on the back of the device before connecting it to the mains. An incorrect setting could damage your device.
Dayton Audio SPA1200DSP Amplificateur Subwoofer 1200W avec DSP et Écran
This amplifier module for Dayton Audio SPA1200DSP subwoofer is capable of delivering no less than 1200W. A significant energy reserve allowing subwoofer enthusiasts to easily use them for deep bass reproduction. This module integrated on a plate can be integrated directly on the subwoofer body for an active subwoofer. The circuit incorporates a powerful DSP (Digital Signal Processor) that allows you to make settings and adjustments via a graphical interface, to adapt the sound to your system and environment. In addition, the SPA1200DSP comes with a control panel that includes a display, status LEDs and a button, to simply change certain parameters such as volume or choice of a predefined filter. These settings can also be made via a dedicated iOS mobile application.
Amplification stage operating diagram
DSP stage operating diagram
Control your subwoofer from your PC
The amplification module integrates a complete and easily configurable DSP via your computer thanks to an intuitive graphical interface. The software allows you to make in-depth modifications to adapt the playback of your subwoofer to your audio system and listening room.
Download software
Tools drop-down menu :
  • Read Setting : Read all the settings from amplifier.
  • Save Settings to File : Save current settings to your PC.
  • Load Settings from File : Load previous saved settings to amplifier
  • Reset to Default Setting : Reset amplifier to factory default settings.
GUI features :
  • USB indicator : When communication via USB with amp is successful, the GUI's "LED" indicator will light blue. Otherwise, the "LED" stays dark.
  • Processing Selection : Selecting any icon can effect change in near-real time (NRT) to the amp's audio outputs.
  • Main Control Screen : Control each DSP processing parameters: Threshold Power, Attack Time, Release, along with 5 digital PEQ bands.
  • Sub In/Out Level Monitor : Monitor the input signal and sub output signal levels.
  • Tools Drop Down Menu : Utilities for amp DSP management, plus Wi-Fi settings.
The GUI's graphical trace is NRT editable. Bands can be shaped by cursor or direct input and/or sliders.
5 bands digital PEQ :
  • a) Band ON/OFF : Bypass or enable by clicking the colorized 1 ~ 5 buttons.
  • b) Center Frequency (CF) : Adjust Center Frequency of each EQ band, 20 ~ 200Hz. Steps: 1Hz.
  • c) Gain : Adjust the EQ gain (apparent volume), -12 ~ +6dB. Steps: 1dB.
  • d) Q (Largeur Égaliseur) : Adjust the "Q" value, 0.4 ~ 11. Steps: 0.1Q.
Limiteur :
  • Threshold : Adjust the limiter "threshold power", 0 ~ -12dB. Steps: 0.1dB
  • Attack : Adjust limiter "attack time". This controls the allowed amount of time signals may be over threshold power. Range of adjustment is 0.1 ~ 100ms (milliseconds). Steps: 0.1ms.
  • Release : Adjust limiter's "release time". When limiter is triggered, this control adjusts the time allowed to restore full power. Adjustable range 100 ~ 5000ms. Steps: 0.1ms.
iEQ™ Intelligent equalizer
The integrated 20Hz microphone allows you to estimate the frequency response characteristics of your listening room and thus apply PEQ filters to compensate for anomalies. To perform this measurement, simply connect the 3.5mm jack connector to the Mic In port of the amplifier.
To measure the acoustics of your room, it will be necessary to move the microphone around your room, especially at the listening point. It is preferable to attach the microphone, for example, with a camera tripod for best results. Only three test points are required, the microphone captures 12 measurements for each location and performs averages.
Starting iEQ : Selecting the GUI's button starts custom calibration test tones. After moving your mic to three different listening locations and estimations are finished, the system screen will display the final measured and calculated post-equalized frequency response results.
Control subwoofer with control panel
The SPA1200DSP comes with a control panel that allows you to simply adjust the active amplifier settings and modify them. The module includes a display, a rotary knob and status LEDs. It can also be integrated directly into the body of your subwoofer alongside the amplifier module.
  • Power ON LED : Green LED when amplifier is operating normally.
  • Standby (STB) LED : Red when amplifier is in energy saving "stand by" state.
  • Feature Setup : Lit when Limiter is active.
  • Screen (128 x 64px) : Liquid Crystal Matrix (LCM) displays all of the feature menu and status..
The Volume setting is selected with a simple press of the button. It is adjustable in 1dB steps. A double press returns you to the main menu. Turning the knob allows you to navigate through the various configuration menus. The parameters shown in the image below correspond to the main functions of the amplifier.
iOS App
Dayton Audio also offers control of the amplifier via an iOS application. It works like a remote control and therefore allows you to change the SPA1200DSP settings from your sofa.
Product typeSubwoofer amplifier
Output power1200Wrms @ 4 Ohm
THD+N< 0.1%
SNR102dB (A-Weighted)
Input impedance22000 Ohm
Power supply110~120V AC / 220~240V AC (Selectable)
Amplifier dimensions241 x 273 x 73mm
Cutout dimensions209.5 x 244.5mm
Control panel dimensions146 x 89 x 32mm
Control panel cutout dimensions120.6 x 63.5mm
Delivered withEU power Cable
Microsoft .NET Framework 3.5 required for software to operate properly. You may need to install .NET Framework 3.5 for use on newer versions of Windows (8.1 or 10).
InputXLR
Power (W)1200.0
This amplifier module for Dayton Audio SPA1200DSP subwoofer is capable of delivering no less than 1200W. A significant energy reserve allowing...
