FX-AUDIO BLAMP-25W TDA7492P Class D Amplifier Module Bluetooth 2x25W
4.3 / 5
Reference : 12136
9,90 €tax incl.
8,25 € tax excl.
FX-Audio TDA7492P
- Amplifier Class D TDA7492P Bluetooth 2x25W -
fx-audio TTDA7492P
This amplifier module incorporates a chip TDA7492P, providing a power of 2x25W. The design of the Class D amplifier makes it a high-performance solution. Equipped with a Bluetooth chip, it will also allow you to stream your music from your sofa.
AMPLIFICATION ST ELECTRONICS TDA7492P
The amplification chip TDA7492P provides efficient amplification at a very low price. With a 10% THD of 20 VDC and an impedance of 8 Ohms, 90% efficiency, 20Hz - 20kHz frequency response, noise reduction and short circuit protection, and excessive temperatures, it turns out to be ideal for mounting small audio systems. Furthermore,the DIP Switch allows you to select the output gain to suit any situation.
BLUETOOTH CS8635
Equipped with a Bluetooth chip CS8635 and a small bluetooth antenna, the module will allow you to stream directly your audio files.
TECHNICAL CHARACTERISTICS
  • Amplifier Chip: ST ELECTRONICS TDA7492P
  • Channels: 2.0
  • Frequency response: 20Hz - 20kHz
  • Power (Max): 2x25W
  • Impedance: 4-6-8-16 Ohms
  • THD (Vcc = 20V, 8 Ohm): 10%
  • Yield: 90%
  • Protections: short circuit, excessive temperatures
  • Bluetooth Chip: CS8635
  • Power supply: DC 9-26V 3-4A / DC Jack 5.5 / 2.1mm (not included)
  • Dimensions: 68 x 63mm
schema TDA7492P + CS8635
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTDA7492PE
Power (W)25.0
3 reviews
Ampli BT 2x25W
produit conforme à la commande
Avantage : très compact et bien fini
Attention, pas de doc technique livré avec.
This review has been posted for FX-AUDIO BLAMP-25W TDA7492P Class D Amplifier Module Bluetooth 2x25W
pas mal mais...
pas facile de souder des fils pour déporter le contrôle de volume
Tres bien
ampli acheté pour réparer un paire d'enceinte creative T40 .Fonctionne parfaitement en conservant les filtres hp.Appairage bluetooth immédiat sous android.Pas de documentation mais l'image sur le site suffit.
