FX AUDIO M-DIY-MINI7498 Class D Amplifier Module TDA7498 2x50W 8 Ohm
Reference : 12224
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 25-04-2025.
FX-Audio M-DIY-MINITDA7498 Amplifier module TDA7498 2x50W
This FX-Audio amplifier module M-DIY-MINITDA7498,M-DIY V4 ​​TDA7498, will allow you to simply set up your DIY amplification system. Capable of delivering 2x50W and enjoying an excellent performance of 90% thanks to its design in Class D, it will be able to adapt to many audio systems. Simple to implement, this one integrates directly on its PCB a volume controller by potentiometer. The module also proposes the addition of a balance control and a Mute / Standby system.
Flexible and adaptive, it is also possible to adjust the gain to 25.6dB, 31.6dB, 35.1dB or 37.6dB via a switch (see diagram below).
Finally, to ensure better durability and resistance to possible damage, the system offers protection against short circuits and thermal overloads.
TECHNICAL CHARACTERISTICS
  • Output Power: 2x50W / 8 Ohms
  • Amplifier Chip: TDA7498
  • Amplification Type: Class D
  • Rendement: 90%
  • Adjustable gain via switch: 25.6dB, 31.6dB, 35.1dB, 37.6dB
  • Integrated heatsink
  • Features: Standby / Mute
  • Requires power supply from: 8 to 24V DC
  • Dimensions (without potentiometer): 87 x 60 x 27 mm
  • Mounting hole spacing: 79 x 51 mm
  • Weight: 86g
Schéma module amplificateur FX-Audio -DIY-TDA7498
InputPCB Connector
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipTDA7498
Power (W)50.0
3 reviews
Livraison rapide et le colis est bien protégé
J'en ai commandé 2, reçu dans une seule et même boite, très bien protégés et emballés dans le carton à l'unité dans des plastiques hermétiques.
Très satisfait !
This review has been posted for FX AUDIO M-DIY-MINI7498 Class D Amplifier Module TDA7498 2x50W 8 Ohm
manque de doc.
Bonjour, le plus sincèrement du monde, nous ne voyons pas quelles informations supplémentaires nous aurions pu ajouter.
produit conforme a la description .bonne realisation
