FX-AUDIO TDA7492-D Class D Amplifier Module TDA7492 2x30W 8 Ohm BTL 100W 4 Ohm
This low-cost FX-Audio amplifier module is based on a TDA7492 amplifier chip allowing it to deliver a power of 2x50W under 8Ω, and this has a high efficiency due to its Class D architecture. The module can also be used in BTL (bridge) mode for a power of 1x100W under 4Ω.
Reference : 13877
9,90 €tax incl.
8,25 € tax excl.
FX-AUDIO TDA7492-D
FX-AUDIO TDA7492 Module Amplificateur TDA7492 2x50W 8Ω BTL 100W 4Ω
This low-cost FX-Audio amplifier module is based on a TDA7492 amplifier chip allowing it to deliver a power of 2x50W under 8Ω, and this has a high efficiency due to its Class D architecture. The module can also be used in BTL (bridge) mode for a power of 1x100W under 4Ω. The amplifier chip is combined with a heat sink to ensure proper heat dissipation. On the connector side there is a PH 2.0mm 3 pins connector at the input and screw terminals at the output for the left and right channels.
The supply voltage must not exceed 18V for use under 4Ω, 24V under 6Ω and 26V under 8Ω.
BTL mode (Bridge) wiring diagram
Product typeAmplification module
Amplification chipTDA7492
Amplification typeClass D
Power2x50W @ 8Ω
BTL : 100W @ 4Ω
Input1x PH 2.0mm 3 pins
OutputSpeaker screw terminals
ProtectionsShort circuit
Thermal overload
Supply voltage10-26V DC (power supply sold separately)
Dimensions71 x 60 x 19.5mm
Fixation holes spacing65 x 52mm
Package1x TDA7492 Amplifier module
1x PH 2.0mm 3 pins to bare wires cable
InputPH 2.0mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTDA7492
Power (W)100.0
Power (W)50.0
This low-cost FX-Audio amplifier module is based on a TDA7492 amplifier chip allowing it to deliver a power of 2x50W under 8Ω, and this has a high...
