FX-AUDIO YDA138-E Class D Amplifier Module YDA138 2x10W 8 Ohm
This small Class D FX-Audio YDA-138-E amplifier module is ideal for integration into a small DIY project that does not necessarily require a large power reserve. Its Yamaha YDA138-E chip allows it to deliver a power of 2x10W.
Reference : 13875
9,90 €tax incl.
8,25 € tax excl.
FX-AUDIO YDA138-E
FX-AUDIO YDA138-EModule Amplificateur Class D YDA138 2x10W 8Ω
This small Class D FX-Audio YDA-138-E amplifier module is ideal for integration into a small DIY project that does not necessarily require a large power reserve. Its Yamaha YDA138-E chip allows it to deliver a power of 2x10W with a high efficiency of 88%, while ensuring a beautiful restitution. The module integrates a 3.5mm Jack connector at the input and a 3.5mm Jack headphone output at the output of the speaker terminals. The output is preceded by a series of 4 filter capacitors to limit noise.
Product typeAmplifier module
Number of channelsStereo (2)
Power2x10W @ 8Ω
Headphone output power2x 50mW @ 32Ω
Amplification chipYamaha YDA138
Amplification typeClass D
Input1x Jack 3.5mm
OutputsSpeaker terminals (maximum Ø3.5mm)
Headphone output Jack 3.5mm
SNR100dB
Efficiency> 88%
Power supply9-13.5VDC 2A via Jack 5.5/2.1mm (sold separately)
PCB Dimensions100 x 66mm
Total dimensions128 x 66 x 18mm
InputJack 3.5mm
OutputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipYDA138-E
Power (W)10.0
pour le prix RAS
produit simple de bonne facture et pour moins de 10€ (hors alim) qui delivre un son clair et de bonne tenue pour permettre une realisation portative compacte. Associe a un convertisseur DC-DC 5V-12V (comme celui vendu sur ce site (Convertisseur DC-DC 5.5V-35V 3A) il permet de brancher l'ampli sur une alim tye chargeur USB ou powerpack Lithium ion (faire attention a l'amperage de l'alim pour utiliser le module a pleine puissance).
This review has been posted for FX-AUDIO YDA138-E Class D Amplifier Module YDA138 2x10W 8 Ohm
This small Class D FX-Audio YDA-138-E amplifier module is ideal for integration into a small DIY project that does not necessarily require a large...
