Hypex NC400 NCore Module mono amplifier 400W (Unit)
Mono Class D audio amplifier for Hi-Fi applications. Offers high power (up to 400W at 1% THD with a 4Ω load) and allows a compact circular size, for various integrations.
By buying this product you get 34 loyalty points
Reference : 14061
349,00 €tax incl.
290,83 € tax excl.
Hypex ncore NC400
Mono amplifier module
hypex-nc400-ncore-module-amplificateur-m
The NC400 module is a class D mono audio amplifier designed for hi-fi applications. It provides a high power (up to 400W 1% THD with a 4Ω load) and enjoy a benefits from a compact form-factor, allowing varied integrations types.
It is suitable for DIY dual mono audiophile amplifier projects, or for making high performance active speakers.
The circuit is designed so that the signal flows only in a path of discrete component. This helps prevent the uptake of noise from the protection & control system from the onboard microprocessor.
With its current capacity of 22A and its low output impedance(Typ: 0.6 / Max 2.5 ohm), this amplification module is ideal for projects requiring high power without altering or compromising the audio precision.
TechnologyNCore
Type amplificationClass D
Power (2Ω, 1kHz, THD = 1%)2Ω, 1kHz, THD = 1%: 580W
4Ω, 1kHz, THD = 1%: 400W
8Ω, 1kHz, THD = 1%: 200W
Canalsx1
Audio InputMolex Microfit header
Audio OutputScrew Terminals
Operational amplifierDiscreet
SMPS voltage +/-64V
Recommended SMPSSMPS600
overvoltage protection72V
Undervoltage protection35V
yieldFull power: 93%
Frequency response0 / -3dB, 0-50kHz
Weight185g
DimensionsDiameter ⌀88mm
Height 37mm
Package Contents
Module NC400 amplifierx1
Mount Set NC400x1
Cable Set NC400Inclued Ncore Signal Cable
Manualx1
NC400 dimensions module Hypex
THD stat NC400 hypex
THD stat N.C.400 hypex
THD stat N C 400 hypex
Frequency response NC 400 hypex
Output Impedance 400 hypex
Distorsion NC hypex
Input
  • PCB Connector
Output
  • PCB Connector
Channel
  • 1 (Mono)
Class
  • Class D / T
Amplifier chip
  • Hypex Ncore
Power (W)
  • 400.0
Download
User manual
Datasheet and user instructions.
Download (2.97M)
Mono Class D audio amplifier for Hi-Fi applications. Offers high power (up to 400W at 1% THD with a 4Ω load) and allows a compact...
