HYPEX NILAI500DIY Mono Class D Amplifier Module 500W 4 Ohm (Unit)
The successor to the NC400 NCore, the Nilai500DIY mono Class D amplifier module from Hypex is also equipped with a totally discrete buffer stage and integrated voltage regulators, but offers much better performance. As a power amplifier module, it delivers power up to 500W at 4 ohm (THD+N 0.00015%). The use of high-end components and a brand-new control loop technology boosts its performance and outperforms the NCore by a factor of 10.
By buying this product you get 42 loyalty points
Reference : 17995
429,00 €tax incl.
357,50 € tax excl.
Shipping date: 22-04-2025.
Grantie 5 ans
HYPEX Nilai500DIY
Class D Mono Amplifier Module 500W 4 Ohm (Unité)
HYPEX Nilai500DIY NILAI Module amplificateur mono Class D 500W 4 Ohm (Unité)
The successor to the NCore NC400, the Nilai500DIY, Hypex's mono Class D amplifier module, also features a totally discrete buffer stage and integrated voltage regulators, but with improved performance. This power amplifier can deliver power of up to 500W at 4 Ohm (THD+N 0.00015%). The use of high-end components and an all-new control loop technology boosts its performance and outperforms its predecessor by a factor of 10. This translates into a distortion factor 10 times lower, power supply noise rejection 10 times higher and output impedance reduced by a factor of 10.
This module is particularly suitable for audiophile DIY amplifier projects in dual mono, or for building high-performance active loudspeakers. The PS500DIY power supply module is also recommended for powering this Nilai500DIY amplifier module.
The circuit is designed so that the signal only travels along a path using discrete components. This avoids the pick-up of parasitic noise from the control and protection system driven by an on-board microprocessor.
With its current capacity of 23A and very low output impedance (40µΩ), this amplifier module is perfect for projects requiring high power without distorting the sound or compromising on audio accuracy.
La connectique du NILAI500DIY par HYPEX
1Molex power input
2Molex signal input
3Speaker output on speaker terminal: - GND / + Signal
4Gain selector (jumper)
Product typeAmplifier module
Amplification typeClass D
TechnologyNilai®
ChannelMono
Output power500W @ 4Ω (THD 0.00015%)
500W @ 2Ω (1kHz, THD 1%)
525W @ 4Ω (1kHz, THD 1%)
260W @ 8Ω (1kHz, THD 1%)
THD+N0.00015%
Output impedance40µΩ
Frequencyr esponse0Hz - 70KHz (+0/-3dB)
Output noise9µV
SNR134dB
Idle power2.25W
Power supply inputMolex 2x 7pins connector (2 lines)
Audio inputMolex 2x 2pins connector (2 lines)
Audio output Speaker screw terminal (do not overtighten, soft alloy screws)
Gain selector jumper
GainLow: 11.8 dB
Mid: 21.8 dB
High: 27.8 dB
Power supply+/-70V
Dedicated high-end PS500DIY power supply recommended
WeightApprox. 200g
Dimensions100*100*40mm
Mounting holes spacing70*70 mm
Mounting screws4* M3
Package1* Hypex Nilai500DIY amplifier module
1* 14-pin Molex power cable
1* 4-pin Molex signal input cable
1* Two-spade cable to bare wires
1* Allen key
1* Torx key
4* Screws
NILAI500DIY Measurements
InputMolex
OutputScrew terminals
Channel1 (Mono)
Amplifier chipHypex Nilai
Power (W)500.0
The successor to the NC400 NCore, the Nilai500DIY mono Class D amplifier module from Hypex is also equipped with a totally...
