HYPEX UcD36MP Amplifier module with power supply 6x30W 4 ohms
Reference : 6936
129,00 €tax incl.
107,50 € tax excl.
This all-in-one (power supply plus amplifier) ​​module from the Hypex range allows you to simplify implementation for any amplification project.
Applications:
  • Stereo or multichannel audio systems
  • Active loudspeakers
Main Features :
  • Advanced overcurrent protection
  • Possibility of remote control
  • High efficiency
  • Universal Input Voltage Range
  • Extremely small form factor
  • Low EMI emissions
  • Power Consumption 10W SMPS (Standby)
Electrical Specifications :
  • Line Input Voltage: High (180 - 264 Vac) Low (90 to 132 Vac)
  • Power: 30Wrms @ 4 ohms per channel
  • Total power: 100Wrms
  • Total nominal power: 70Wrms @ 20Hz
Mechanical characteristics :
  • Weight: 200g
  • Dimensions: 185 x 70 x 31.6 mm
To operate the module: J2: 1 connected to J2: 4, and J2: 7 connected to J2: 8.
https://www.audiophonics.fr/images2/6936/6936_HYPEXUCD36MP_1.jpg
Example of implementation:
https://www.audiophonics.fr/images2/7348/7348_HIFI2000_HYPEX_UCD36_5.jpg
Case sold here(click here)
https://www.audiophonics.fr/images2/6935/6935_UCD34MP_2.jpg
Datasheet Manufacturer (PDF)
PIN 1+ 5V standby
PIN 2GND Standby
PIN 3NTC connection
PIN 4Enabling Entries
PIN 5- Vamp
PIN 6+ Vamp
PIN 7Amp_EN
PIN 8GND Amplifiers
PIN 9Cold spot CH1
PIN 10Hot spot CH1
PIN 11Cold spot CH2
PIN 12Hot spot CH2
PIN 13Cold spot CH3
PIN 14Hot spot CH3
PIN 15CH4 cold spot
PIN 16Hot spot CH4
PIN 17CH5 cold spot
PIN 18Hot spot CH5
PIN 19CH6 cold spot
PIN 20Hot spot CH6
Channel6
