ICEPOWER 1200AS2 Stereo Class D Amplifier Module 2x1200W 4 Ohm
This IcePower 1200AS2 amplifier module is a stereo Class D amplifier module based on ICEedge technology capable of delivering 2x 1200W @ 4 ohm (THD+N ≤ 1%). The module incorporates its own switched-mode power supply stage (SMPS) including a PFC (Power Factor Correction) to guarantee clean power supply to the amplifier stage.
By buying this product you get 42 loyalty points
Reference : 19116
429,90 €tax incl.
358,25 € tax excl.
Shipping date: 24-04-2025.
Photo of ICEPOWER 1200AS2 module
This IcePower 1200AS2 amplifier module is a stereo Class D amplifier module based on ICEedge technology capable of delivering 2x1200W under 4 ohm (THD+N ≤ 1%). The module incorporates its own switching-mode power supply stage (SMPS) including a PFC (Power Factor Correction) to guarantee clean power supply to the amplifier stage. The power supply complies with ErP and ENERGY STAR standards. It also offers comprehensive protection and monitoring functions via an easy-to-use control interface. In fact, dedicated control outputs for speaker connector output voltage and current enable real-time protection of your sound system.
In addition, the 1200AS2 module is optimized for excellent heat dissipation thanks to an underlying aluminum plate, which also facilitates module mounting for rapid integration. The module also features a power output for easy powering of an external module, as well as 2 control ports.
This module has been designed to deliver state-of-the-art audio performance and power. This module is perfect for professional subwoofers, 2-way and 3-way loudspeakers, line arrays, consumer active loudspeakers or high-end amplifiers.
Overview of the ICEPOWER 1200AS2 amplifier module (Stereo)
ICEPOWER 1200AS2 module connectors
P100JST AC Mains Connector
P101Basic Control Connector
P102Advanced Control Connector
P103Hanger Control Connector
P104: Hanger Rail Supply Connector
P105Audio Input Connector
P106Voltage and Current Monitor Output Connector
P107Audio output channel 1 balanced
P108Audio output channel 2 balanced
Product typeAmplifier module
Amplification typeClass D
Channels2 (Stereo)
Inputs1x JST AC main power connector 3pins
1x HP JST audio input connector 6pins
Outputs1x JST channel 1 output connector 4pins
1x JST channel 2 output connector 4pins
1x JST output connector for voltage and current control 8pins
1x JST hanger rail supply connector 3pins
1x JST hanger control connector 8pins
Control ports1x JST basic control connector 14pins
1x JST advanced control connector 22pins
Output power2x 1200W @ 4 ohm (≤ 1%, 1kHz)
2x 600W @ 8 ohm (≤ 1%, 1kHz)
THD+N0.003 % THD+N @ 1 kHz, 10 W / 4 Ohm
Bandwidth50kHz
Dynamic range129dB
Output noise30uV A-weighted
Minimum load impedance2.7 Ohm
Maximum output voltage / current100Vp / 38Ap
Auxiliary supply outputs+5VDC et +/-15VDC
Power supply100-240V AC 50/60Hz
Dimensions300 x 100 x 63mm
Package1x ICEPOWER 1200AS2 stereo amplifier module
1x Cable kit for 1200AS2
InputPCB Connector
OutputPCB Connector
Channel2 (Stereo)
Amplifier chipN/A
Power (W)1200.0
ICEPOWER 1200AS1 Stereo Class D Amplifier Module 2x1200W 4 Ohm
This IcePower 1200AS2 amplifier module is a stereo Class D amplifier module based on ICEedge technology capable of delivering 2x 1200W @ 4...
