ICEPOWER 125ASX2 Class D Stereo / Mono Amplifier Module 2x215W / 1x450W 4Ω
The ICEpower 125ASX2 is a compact Class D amplifier module that can operate in both stereo and mono. It is thus capable of delivering a power of 2x125W under 4Ω or 1x450W under 4Ω, while ensuring a precise and detailed sound reproduction.
By buying this product you get 22 loyalty points
Reference : 17318
229,00 €tax incl.
190,83 € tax excl.
Shipping date: 24-04-2025.
ICEpower 125ASX2
ICEpower 125ASX2 Module amplificateur Stéréo/Mono Class D 2x125W / 1x450W 4Ω
The ICEpower 125ASX2 is a compact Class D amplifier module that can operate in both stereo and mono. It is thus capable of delivering a power of 2x125W under 4Ω or 1x450W under 4Ω, while ensuring a precise and detailed sound reproduction. It also embeds its own power supply stage for a minimum size, a great ease of integration and above all peak performance. Its auxiliary power supply output allowing to supply external modules as well as the elimination of any heatsink or EMI shielding favors even more this ease of implementation of the module. It also benefits from a series of protections against short-circuits, overloads and overheating.
Product typeAmplifier module
Amplification typeClass D
ChannelsStereo (2) / Mono (1)
Input1* Analog input on JST 8 pins connector
OutputSpeaker output on JST 4 pins connector
Output power @ SE, THD+N 1%, 20Hz-20kHz125W @ 4
150W @ 8
Output power @ BTL, THD+N 1%, 20Hz-20kHz450W @ 4Ω
Output power @ SE, THD+N 10%, 20Hz-20kHz150W @ 4
Output power @ BTL, THD+N 10%, 20Hz-20kHz550W @ 4Ω
Minimum load impedance3Ω
Maximum total amp + PSU efficiency86%
Peak output current20A
Dynamic rangeSE : 117dB
BTL : 121dB
Noise floor @A-WeightedSE : 30µV
BTL : 36µV
THD+N (1W/1kHz)0.003%
Gain24.3dB
Supply voltage85-264VAC (supply voltage switchable via jumper)
Dimensions160*80*32.6mm
Package1* ICEpower 125ASX2
Wiring cables
InputPCB Connector
OutputPCB Connector
Channel2 (Stereo)
Channel1 (Mono)
Amplifier chipN/A
Power (W)125.0
Power (W)450.0
The ICEpower 125ASX2 is a compact Class D amplifier module that can operate in both stereo and mono. It is thus capable of delivering a power of...
