ICEPOWER 2000AS1 HV Mono Class D amplifier module 1x2000W 4 Ohm
The ICEPower 2000AS1 HV is a Class D mono amplifier module based on IceEdge technology, capable of delivering up to 1x2000W of power at 4Ω. It features its own switch-mode power supply stage (SMPS) including PFC (Power Factor Correction) for a power supply of flawless reliability and stability.
Reference : 18011
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 17-04-2025.
ICEPOWER 2000AS1 HV
ICEPOWER 2000AS1 HV Module Amplificateur Mono Class D 1x2000W 4 Ohm
The ICEPower 2000AS1 HV is a Class D mono amplifier module based on IceEdge technology, capable of delivering up to 1x2000W of power at 4Ω. It features its own switch-mode power supply stage (SMPS) including PFC (Power Factor Correction) for a power supply of flawless reliability and stability. Its power supply is a universal ErP power supply that complies with international standards.
In addition, the module is optimized for excellent heat dissipation thanks to an aluminum backplate, which also facilitates mounting of the module for rapid integration. The module also features a power output for easy powering of an external module, plus 2 control ports.
This module has been designed to deliver peak audio performance and power. This module is perfect for professional subwoofers, 2-way and 3-way loudspeakers, line arrays, consumer active loudspeakers or high-end amplifiers.
Product typeAmplifier module
Amplification typeClass D
ChannelsMono
Inputs1x JST AC main power connector 3pins
1x HP JST audio input connector 6pins
Outputs1x JST audio output connector 4pins
1x JST output connector for voltage and current control 8pins
1x JST hanger rail supply connector 3pins
1x JST hanger control connector 8pins
Control ports1x JST basic control connector 14pins
1x JST advanced control connector 22pins
Power1x 2000W @ 4Ω (THD+N ≤ 1%, 1kHz)
1x 1400W @ 8Ω (THD+N ≤ 1%, 1kHz)
THD+N0.001% @ 1kHz, 10W / 4 Ohm
Bandwidth40Khz
Output noise38µV A-weighted
Minimum load impedance3
Maximum output voltage / current 149V 38A
auxiliary supply outputs+5V DC and +/-15V DC
Power supply100-240V AC 50/60Hz
Dimensions300 x 100 x 64 mm
Package1x Mono amplifier module ICEPOWER 2000AS1 HV
1x Cable kit for 2000AS1
InputPCB Connector
OutputPCB Connector
Channel1 (Mono)
Amplifier chipN/A
Power (W)2000.0
The ICEPower 2000AS1 HV is a Class D mono amplifier module based on IceEdge technology, capable of...
