ICEPOWER 200AS2 Class D Stereo Amplifier Module 2x215W 4Ω
The ICEpower 200AS2 is a compact Class D stereo amplifier module that can deliver a substantial 2x215W of power at 4Ω while ensuring accurate and detailed sound reproduction. It embeds its own switch-mode power supply (SMPS) for minimum space requirements, ease of integration and above all peak performance.
Reference : 17317
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 24-04-2025.
ICEpower 200AS2
ICEpower 200AS2 Module amplificateur stéréo Class D 2x215W 4Ω
The ICEpower 200AS2 is a compact Class D stereo amplifier module that can deliver a substantial 2x215W of power at 4Ω while ensuring accurate and detailed sound reproduction. It embeds its own switch-mode power supply (SMPS) for minimum space requirements, ease of integration and above all peak performance. The SMPS is capable of delivering 300W of continuous power to the amplifier circuit. In addition, the card is optimized for excellent heat dissipation, allowing for use without the addition of a fan and ensuring excellent durability. The module also features a power supply output for easy powering of an external module as well as a control port.
Product typeAmplifier board
Amplification typeClass D
ChannelsStereo (2)
Input1* Analog input on 6 pins JST connectors
OutputsSpeaker outputs on 2 pins JST connectors
Output power2*215W @ 4Ω, 20Hz-20kHz, THD+N 1%
2*120W @ 8Ω, 20Hz-20kHz, THD+N 1%
2*260W @ 4Ω, 20Hz-20kHz, THD+N 10%
Minimum load 3.5Ω
Max amp + PSU total efficiency70%
Max output current13A
Dynamic range110dB
Output noise92µV
THD+N (10W/1kHz)0.004%
Input sensitivity2.5Vp
Gain24dB
Automatic signak detection
Supply voltage100-240VAC (power supply not included)
Dimensions158*77*36.5mm
Package1* ICEpower 200AS2
Wiring cables
InputPCB Connector
OutputPCB Connector
Channel2 (Stereo)
Amplifier chipN/A
Power (W)215.0
The ICEpower 200AS2 is a compact Class D stereo amplifier module that can deliver a substantial 2x215W of power at 4Ω while ensuring...
