ICEPOWER 250ASX2 Class D Stereo / Mono Amplifier Module 2x230W 4Ω / 1x500W 8Ω
The ICEpower 250ASX2 is a compact Class D amplifier module that can operate in both stereo and mono. It is thus capable of delivering a power of 2x230W under 4Ω or 1x500W under 8Ω, while ensuring a precise and detailed sound reproduction.
By buying this product you get 32 loyalty points
Reference : 17319
329,00 €tax incl.
274,17 € tax excl.
ICEpower 250ASX2
Module Amplificateur Stéréo / Mono Class D 2x230W 4Ω / 1x500W 8Ω
ICEpower 250ASX2 Module amplificateur Stéréo/Mono Class D 2x230W 4Ω / 1x500W 8Ω
The ICEpower 250ASX2 is a compact Class D amplifier module that can operate in both stereo and mono. It is thus capable of delivering a power of 2x230W under 4Ω or 1x500W under 8Ω, while ensuring a precise and detailed sound reproduction. It also has its own power supply stage for a minimum footprint, ease of integration and, above all, top performance. Its ±24VDC auxiliary power supply output, which can be used to power external modules, as well as the elimination of any heat sink or EMI shielding, makes the module even easier to implement. It also benefits from a series of protections against short-circuits, overloads and overheating.
Product typeAmplifier board
Amplification ty^peClass D
ChannelsStereo (2) / Mono (1)
Input1* Analog input on JST 8 pins connector
OutputSpeaker output on JST 4 pins connector
Output power @ SE, THD+N 1%, 20Hz-20kHz2x230W @ 4Ω, 230VAC
2x200W @ 4Ω, 115VAC
Output power @ BTL, THD+N 1%, 20Hz-20kHz1x500W @ 8Ω, 230VAC
1x420W @ 8Ω, 115VAC
Minimum load impedance3Ω
Maximum total amp + PSU efficiency81%
Peak output current20A
Dynamic range125dB
Output noise @ A-Weighted20µV
THD+N (1W/1kHz)0.002%
Supply voltage85-264VAC (supply voltage switchable via jumper) (power supply not included)
Dimensions210*80*35mm
Package1* ICEpower 250ASX2
Wiring cables
InputPCB Connector
OutputPCB Connector
Channel1 (Mono)
Channel2 (Stereo)
Amplifier chipN/A
Power (W)500.0
Power (W)230.0
The ICEpower 250ASX2 is a compact Class D amplifier module that can operate in both stereo and mono. It is thus capable of delivering a power of...
