IRS500SMPS Amplifier Mono Class D 300W / 500W
Reference : 8786
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 22-04-2025.
IRS500SMPS 500W @ 4 Ohm
Produced all in one to simplified implementation, this module incorporates a Mono Class D power amplifier capable of providing 300W under 8 Ohms, or 500W 4 Ohm.
It is equipped with a regulated power supply isolated directly on the PCB and therefore does not require a toroidal transformer.
Compact, lightweight, practical and dynamic, it can be used in any audio assembly requiring high dynamics and good power reserve.
FEATURES
ModuleIRS500SMPS
ProtectionShort circuit
Overvoltage
Overheating
Speakers
Anti "ploc"
THD0.1 %
Mute FunctionYes
Aux Output+/- 15V
Output Power300W @ 8 ohms / 500W @ 4 Ohm
Dimensions150 x 50 x 36mm
Weight300g
Contents of the package
IRS500SMPS amplifier modulex1
Cable XH 10-pole with housing to bare wiresx1
VH 2-pole cable with box to bare wiresx1
InputNC
OutputNC
Channel1 (Mono)
Amplifier chipN/A
Power (W)500.0
4 reviews
Great Versatility
I bought 2 modules of these amplifiers to be able to power a dual 4 Ohm coil 1000 Watts Subwoofer, the results are surprisingly good, the combined amplifiers work perfect and at warm temperatures even in heavy loads.
I am amazed, by the incredibly reduced size, of the power and sound quality this units can provide.
This review has been posted for IRS500SMPS Amplifier Mono Class D 300W / 500W
CAISSON BASSE
Matériel reçu rapidement mais présentant des trace d'usure sur
le bloc de refroidissement en aluminium
alain
Ampli 2X500W à base de IRS500SMPS
Excellent module que j'ai monté en bloc stéréo à entrées XLR.
De plus, l'alimentation intégrée avec soft Start est maintenant trés performante, chauffe peu aprés quelques mois de fonctionnement continu.
La qualité sonore est exceptionnelle et est supérieure aux blocs Nuforce Ref 9 SE V2 dans touts les registres aigus, médiums et procure un grave étonnant (rapide et détaillé) qui ont donné à mes 906 un statut proche d'une colonne.
Permet de faire un bloc stéréo et même multicanal de qualité extra et de taille réduite (pour peu qu'on soigne la convexion en perçant des trous et qu'on monte le rail du radiateur avec de la corniére alu bien vissée au fond du boitier),
un rapport Q/P exceptionnel.
Un conseil : mettre le volume à zéro à la mise sous/hors tension, ça évite toute éventuelle mauvaise surprise arrivée sur un autre bloc stéréo Connex (sous garantie)qui fut remplacé sans pb par Audiophonics.
Permet de faire un bloc stéréo et même multicanal de qualité extra et de taille réduite, un rapport Q/P exceptionnel.
