JUSTBOOM AMP HAT Stereo Amplifier TAS5756 2X30W 8 Ohm
Reference : 11604
69,90 €tax incl.
58,25 € tax excl.
JustBoom Amp HAT
Justboom Amp HAT Amplificateur Stéréo TAS5756 2x30W 8 Ohm
This is the only 32bit 192kHz amplifier dedicated to the Raspberry Pi2 and Pi3 you'll need! The JustBoom Amp HAT TAS5756 is designed to be easy to install and use. With no soldering required and supplied with all assembly accessories, this product will be suitable for both professionals and beginners. Simply connect your HAT Amp to a set of passive speakers and your system is operational and allows you to enjoy high quality audio playback. An optional IR receiver (to be soldered) is also provided, so you can control your amplifier remotely.
This amplifier is based on a TAS5756 Class D 32bit 192kHz amplifier chip, for a peak power of 2x25W. The JustBoom Amp HAT accepts speaker cables up to 14AWG (2.08mm²) in cross-section on screw terminals. The amplifier can be combined with passive loudspeakers with an impedance from 8Ω to 4Ω and offers a clear and crystal clear sound reproduction. The HAT uses the I2S interface for its audio input, which reduces the CPU load on the Raspberry Pi compared to USB solutions. It is also designed to back-power the Raspberry Pi on the 40-pin GPIO connector. All it takes is one power supply for the entire system.
Finally, all unused pins of the Raspberry Pi GPIO are always available on the Amp HAT to facilitate the customization of your project. Addition of sensors, buttons, LEDs, rotary encoders, everything is possible!
We recommend the use of a 15V 65W 2.5A 15V 65W power supply
It is possible to adjust the gain to suit your system. To do this, simply move jumper J5 of the module. The following table allows you to know how to adjust the gain.
Speaker impedanceAmplifier gainAlsamixer volumePower sourceSupply voltagePeak powerMax power (RMS)Power supply
4Ω20dB-8dBRaspberry Pi5V6W3W17W
4Ω20dB-1.5dBExternal12V30W15W45W
4Ω20dB0dBExternal15-19V40W20W58W
8Ω20dB-8dBRaspberry Pi5V3W1.5W14W
8Ω20dB-1dBExternal12V18W10W34W
8Ω20dB+1dBExternal15-19V25W15W45W
8Ω26dB0dBExternal24V55W30W75W
JustBoom Amp HAT review by ON-mag.fr
" The JustBoom offer combined with Max2Play software is an excellent solution for creating a large, energy-efficient, easy-to-install multi-room system.. "
Test du JustBoom Amp HAT par ON-mag.fr
Example of assembly with a Raspberry Pi 3
(Raspberry Pi sold separately)
Product typeAmplifier module
Supported sampling rateUp to 32bit 192kHz
Max powerPeak : 2x55W 8Ω
RMS : 2x30W Ω
Hardware and software volume control for Raspberry Pi-
Gain20dB
26dB
RPI compatibilityRaspberry Pi A+, B+, 2B, 3B
OS compatibilitéOSMC, Max2Play, RuneAudio, Volume, Moode, piCorePlayer, PiMusicBox, OpenElec
Supply voltage8-24V DC 2.5A (power supply sold separately)
Package1x JustBoom Amp HAT
1x IR receiver to solder
Screws
1x Roon Labs access card
1x Max2Play access card
InputGPIO
OutputScrew terminals
DAC / ADC ChipNC
Channel2 (Stereo)
Amplifier chipTAS5756
Power (W)30.0
