LME49810 2SC5200 Amplifier board 300W 8 ohm Mono (1 unit)
Reference : 11189
82,00 €tax incl.
68,33 € tax excl.
Shipping date: 25-04-2025.
This high precision mono bipolar amplifier delivers 300 W under 8 ohm. Equipped with precision metal resistors, quality capacitors, this kit is ideal for high power amplification modules with high-fidelity sound quality. It is designed around 6 bipolar transistors 2SC5200 NPN and 2SA1943 PNP of high quality Toshiba. Their modularity and ease of implementation make them a reference choice for any dual mono stereo DIY amplifier project or for multichannel amplifiers. These transistors are controlled by the integrated driver " LME49810" with a "Soft Clipping" overload protection system.
Power supply for module
Two power supply modes are available for the module: a simple 2-rail power supply with +Vcc and -Vcc, and a 4-rail power supply with V+ and V- to optimize the module's drive stage and achieve better output.
2-rail power supply: +Vcc and -Vcc terminals require a +/-50V DC power supply.
Optimized 4-rail power supply: V+ and V- terminals must be supplied with a value greater than or equal to the +Vcc and -Vcc terminals. For optimum rendering, we recommend +/-55V DC for terminals V+ and V-.
The quiescent current (bias) must be set to 10mV between the cement resistor terminals, using the blue potentiometer.
Adjusting the bias of the LM49810 2SC5200 amplifier module
To do this, connect your multimeter across the terminals of a 0.22 ohm cement resistor. Make an initial cold setting of 10mv, then wait 15min for heating, then readjust the value to 10mv. If the terminals of the 0.22 ohm cement resistors are not accessible, you can also perform the adjustment on the transmitter terminal and the output coil terminal.
Quiescent current adjustment diagram
1Cement resistors 0.22 ohm
2Transmitter point
3Output coil terminal
Single module sold per unit.
Main Features:
  • Power Transistors: BIPOLAR NPN TTC5200x3, PNP TTA1943x3.
  • Transistor stage transistor: LME49810.
  • 8 capacitors 680μF 63V.
  • Mono input stage OP AMP TL071 JFET.
  • Output power: 300W on 8 Ohm.
  • Recommended average operating voltage 55 VDC.
  • Frequency response: 20Hz - 25kHz + -0.5dB.
  • Noise background 93dBu.
  • Slew-rate: 50V / us.
  • Distortion rate: 0.0007% at 1 K HZ 50W on a resistance of 8Ohm.
  • Signal-to-Noise Ratio (SNR):> 114dB.
Requires to operate a power supply of at least + /-55V VCC (See accessory).
Inputs and outputs:
  • Power supply and speaker output via screw terminal block.
  • Mono input via screw terminal block.
Dimensions and weight:
  • PCB dimensions: 207x93x35mm.
  • Mounting brackets: 207X84mm.
  • Weight: 305gr the mono module.
  • Sold individually.
  • Supplied with insulation film for power transistors.
  • Supplied with spacers.
Provide a linear supply of +/- 55V and a transformer from 30V AC to 38V AC.
Amplifier module diagram
InputScrew terminals
OutputScrew terminals
Channel1 (Mono)
ClassClass A / AB
Amplifier chipTransistors
Power (W)300.0
Super module
Je m'en suis servi pour alimenter un subwoofer en dessous de 70Hz, mais je l'ai essayé en large bande.
En large bande, c'est pas mal.
Plutôt doux avec pas mal de dynamique.
Mais en utilisation subwoofer, c'est vraiment excellent.
plutôt plus riche et plus vif et "punchy" que les différents classe D que j'ai pu essayer (IcePower entre autres, que j'avais précédemment choisi car les hps s'affolaient moins à haut niveau qu'avec d'autres modules).
Là, malgré une puissance limitée (choix du transfo) vers 230W, c'est vraiment superbe.
J'y ai associé un filtre actif analogique complètement diy avec un correcteur Linkwitz intégré (pour avoir du 15Hz -3dB in room)...
This review has been posted for LME49810 2SC5200 Amplifier board 300W 8 ohm Mono (1 unit)
