LJM's L15 is a dual mono amplifier module kit, each delivering 150W under 8Ω. These are based on 3 IRFP240 MOSFETs and 3 IRFP9240 MOSFETs used in a Class AB architecture. These modules support power supplies ranging from ±15V to ±70V. Each of the two modules is delivered attached to an aluminium plate, ready to be fixed within an enclosure.
Product type | Power amplifier modules |
Power transistors | 3x IRFP240 3x IRFP9240 |
Output power | 150W @ 8Ω, ±55VDC 300W @ 4Ω, ±55VDC 600W @ 2Ω, ±55VDC |
Architecture | Class AB |
Frequency response | 10Hz - 30kHz (-0.05dB) |
Total harmonic distortion (THD) | 0.02 % @ 150W, 8Ω |
SNR | > 97dB |
Voltage gain | 31x |
Input | 1x Screw terminal |
Output | 1x Solder pads |
Power supply voltage | ±15V - ±70V DC |
Dimensions | PCB : 40 x 150mm PCB + Aluminium plate : 74 x 150mm |
Spacing holes | 138.5 x 28.5mm |
Weight | 350g |
Package | 2x LJM L15 |
Input | Screw terminals |
Output | Solder pad |
Channel | Dual Mono |
Class | Class A / AB |
Amplifier chip | Transistors |
Power (W) | 150.0 |
