LJM L7 Mono Amplifier Modules (Pair)
LJM's L7 is a dual mono amplifier module kit, each delivering 150W into 8Ω. These are based on an IRFP240 MOSFET and an IRFP9240 MOSFET, both from Vishay, and benefit from a Class AB architecture. In order to offer the best possible performance, these modules also benefit from a complementary feedback pair circuit (also known as Sziklai Pair) and MKP coupling capacitors.
Reference : 19983
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 24-04-2025.
LJM L7 Mono Amplifier Boards 150W 8Ω (Pair)
LJM L7 : 3/4 view
Product typePower amplifier modules
Power transistors1x Vishay IRFP240
1x Vishay IRFP9240
Output power150W @ 8Ω
300W @ 4Ω
350W @ 8Ω
Frequency response4Hz - 35kHz
Total harmonic distortion (THD)< 0.01% @ 100W 1kHz
InputScrew terminal
OutputSolder pads
Slew rate38V/μsec
Signal-to-noise ratio (SNR)99dB
ArchitectureClass AB
Power supply voltage±15V - ±65V DC
Dimensions63 x 73mm
Spacing holes52 x 62mm
Weight125g
Package2x LJM L7
4x Silicone insulation for transistor
8x Blade terminals
InputScrew terminals
OutputSolder pad
ChannelDual Mono
ClassClass A / AB
Amplifier chipTransistors
Power (W)150.0
LJM L7 Mono Amplifier Modules 150W 8Ω (Pair)
LJM's L7 is a dual mono amplifier module kit, each delivering 150W into 8Ω. These are based on an IRFP240 MOSFET and an IRFP9240...
