LJM MX100 Stereo Amplifier Module
The MX100 is a stereo amplifier module delivering 100W of power at 8Ω. It uses 2 Toshiba TTC5200 transistors and 2 Toshiba TTA1943 transistors. This module also includes a speaker protection, a rectifier filter for the power supply and an overcurrent protection. All you need to do is connect this module to a transformer, which the manufacturer recommends should have a power rating of at least 200W.
Reference : 19976
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 24-04-2025.
LJM MX100 Stereo Amplifier Board 100W 8Ω
LJM MX100 : 3/4 view
The LJM MX100 is a stereo amplifier module delivering 100W of power at 8Ω. It uses 2 Toshiba TTC5200 transistors and 2 Toshiba TTA1943 transistors. This module also includes a speaker protection, a rectifier filter for the power supply and an overcurrent protection. All you need to do is connect this module to a transformer, which the manufacturer recommends should have a power rating of at least 200W.
Product typePower amplifier modules
Power transistors2x Toshiba TTC5200
2x Toshiba TTA1943
Output power100W @ 8Ω
200W @ 4Ω
Frequency response10Hz – 100kHz (-3dB)
Total harmonic distortion (THD)< 0.008 @ 50W, 1kHz
InputScrew terminal
OutputScrew terminal
Damping factor1500 @ 8Ω
Efficiency70%
Power supply voltage24V AC
Dimensions113 x 144mm
Spacing holes100 x 133mm
Weight300g
Package1x LJM MX100
4x Silicone insulation for transistor
InputScrew terminals
OutputScrew terminals
Channel2 (Stereo)
ClassN/A
Amplifier chipTransistors
Power (W)100.0
LJM MX100 Stereo Amplifier Module 100W 8 Ohm
The MX100 is a stereo amplifier module delivering 100W of power at 8Ω. It uses 2 Toshiba TTC5200 transistors and 2 Toshiba TTA1943...
