Stereo version based on the famous LM3886, this Amplifier module is equipped with a SMPS power supply and two LM3886T Class AB amplifiers.
Its output power is 2x 60W under 4 Ohm and up to 2x 40W under 8 Ohm with a THD of less than 0.01%.
It has the particularity of not using a coupling capacitor on the signal path without adding any color to the sound, which gives it a high degree of neutrality.
A heat sink must be used for reliable operation.
This module has a sophisticated protection system for overvoltages, undervoltages and ploc (delay) in order to preserve your loudspeakers.
The default voltage is 230V, selectable at 110V by jumper / jumper.
Easy to implement and small format, it will prove an excellent choice for any DIY amplifier project.
Characteristics :
