LME49830 2SK1530 FET Amplifier board 100W 8 Ohm Mono (1 unit)
Reference : 11190
69,00 €tax incl.
57,50 € tax excl.
This high accuracy mono FET amplifier delivers 100 W under 8 ohm. Equipped with precision metal resistors, high quality capacitors, this kit is ideal for high-power amplifier modules with high fidelity quality sound that favors harmonics of type 2 (tube sound).
It is designed around Toshiba's high quality 2SJ1201, PNP 2sk1530 FET transistors.
The modularity and ease of implementation makes it a reference choice for any dual mono stereo DIY amplifier project or the realization of multichannel amplifiers.
These transistors are controlled by the integrated driver " LME49830" with an advanced overload protection system "Soft Clipping".
Single module sold per unit.
Main Features:
  • Power Transistors: FET 2sj1201, PNP 2sk1530
  • Transistor Floor Driver: LME49830
  • 4 capacitors 330μF 63V
  • Mono input stage OP AMP TL071 JFET
  • Output Power: 100W on 8 Ohm
  • Frequency response: 20Hz - 25kHz + -0.5dB
  • Background noise 92dBu
  • Slew-rate: 39V / us
  • Distortion rate: 0.0015% at 1 K HZ 50W on a resistance of 8 Ohm
  • Signal Noise Ratio (SNR):> 105dB
Requires a +/- 55V power supply
Inputs and outputs:
  • ATsupply and output via screw terminal block
  • Mono input via screw terminal block
Dimensions and weight:
  • PCB Dimensions: 152x93x30mm
  • Mounting brackets: 144x81mm
  • Weight: 182gr the mono module
Sold individually.
  • Supplied with insulation film for power transistors
Channel1 (Mono)
ClassClass A / AB
