LQSC Class AB 4.0 Amplifier Board TDA7850 4x50W 4 Ohm
This high quality Class AB amplifier module with 4 channels is capable of developing a power of 4x80W under 4Ω, thanks to a TDA7850 chip offering what is more a rich and musical sound reproduction. The latter is mounted on a large heatsink allowing to dissipate efficiently the heat released.
Reference : 16235
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 29-04-2025.
LQSC 4.0 Amplifier Board
Class AB TDA7850 4x50W 4 Ohm
LOSC Module Amplificateur 4.0 Class AB TDA7850 4x50W 4 Ohm
This high quality Class AB amplifier module with 4 channels is capable of developing a power of 4x50W under 4Ω, thanks to a TDA7850 chip offering what is more a rich and musical sound reproduction. The latter is mounted on a large heatsink allowing to dissipate efficiently the heat released. The input is done in 3.5mm stereo jack or XH2.54mm connectors, while the output uses screw terminals for an easy and quick assembly. The module also incorporates two potentiometers to control the volume level per pair of speakers (e.g. front and rear speakers).
The ACC terminal must be connected to the + terminal of the power supply terminal block.
1Rear channels volume
2High-end sealed potentiometer
3Front channels volume
4Black high-end PCB
5External Mute feature
6Jack 3.5mm inputs
7Custom KEMET capacitors
8Copper screw terminals
94x 3300µF filtering capacitors
10Copper screw terminals
11Metal resistance
12TDA7850 Amplification chip
13Heatsink
Product typeAmplifier board
Amplification typeClass AB
Amplification chipTDA7850
Number of channels4
Output power4x50W @ 4Ω, 18V
Inputs2x Jack 3.5mm
2x XH2.54mm 3 pins
OutputsSpeaker terminals (screw terminals)
ProtectionsOverload
Short circuits
Thermal protection
Supply voltage12-18V DC
Dimensions72.36 x 97 x 27mm
Mounting holes sapcing64.7 x 52.14mm
Weight171g
InputXH 2.54mm
InputJack 3.5mm
OutputSpeaker terminal
Channel4
ClassClass A / AB
Amplifier chipTDA7850
Power (W)50.0
2 entrées - 4 canaux
je l'ai pris pour Alimenter les tweeter et medium d'une paire d'enceinte 3voies à 3ampli avec filtration active par DSP. Ne chauffe pas en 12V.
le rendu sonore me parait meilleur qu'avec les 2 ampli 2x50W de class D qu'il remplace.
This review has been posted for LQSC Class AB 4.0 Amplifier Board TDA7850 4x50W 4 Ohm
This high quality Class AB amplifier module with 4 channels is capable of developing a power of 4x80W under 4Ω, thanks to a TDA7850 chip...
